picture size
webmario
Monitor/Display Make & Model: moon
picture size
Post by webmario »
Before I start to work on a picture, the size is around 2MB. After small corrects my pictures are only 0.3 to 0.5MB.
Why? Is there a possibility to have the same picture size like before?
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: picture size
Post by Forriner »
I'm assuming you're talking about the .JPG file format. But, options are there in many other file formats.
The next time you edit a .JPG, don't 'Save' it but 'Save as...'. At the bottom right of the dialogue box, if you've selected the JPG file type, there's an 'Options' button.
On that dialogue you'll see 'Compression' with a slider and an entry box. Out of the box it's usually set to 15% (or maybe 20). slide the slider to the left -least compression- or fill in 1 in the box. This will give minimal compression.
Once you've done that, the Save option uses the same compression factor as the Save as... option.
