Pro X6 Manage View folders are closed.
kalidor
motherboard: Dell Inc. 083HX3 A11
processor: 2.40 gigahertz Intel Core i5-2430M
ram: 8Gb
Video Card: NVIDIA GeForce GT 525M
sound_card: NVIDIA Virtual Audio Device
Hard_Drive_Capacity: 750
Monitor/Display Make & Model: Generic PnP Monitor (15.3")
Post by kalidor »
When I start Paint Shop Pro X6 in Manage View I have to each time open My computer folder and work down to find My Pictures.
This was not always the case and has only started happening recently. I have been into the settings to make sure that Manage
is the screen that opens first. I tried last view but this didn't help. Any ideas?
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: Pro X6 Manage View folders are closed.
Post by MarkZ »
kalidor wrote:When I start Paint Shop Pro X6 in Manage View I have to each time open My computer folder and work down to find My Pictures.
I'm aware that there are others who have had this problem and I don't know if anyone has found a solution - Tadjio?
One way to make your life easier would be to put the folders you use most often in Collections. That way you will have a much shorter path to the folder you want.
Mark
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
In my case with X6 32 on an XP SP3 machne. If I select a folder on the desktop , that folder is remembered and whenever I switch to Manage mode (Whether opening in Manage mode or Opening in Edit mode - my preference and switching to Manage mode) . JUst as well a My Pictures has so many images in it that I would be searching for some time.
I find it easier and safer to place copies any images I want to work on in a desktop folder.
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
Yes, I have the same problem regarding folders in "My Computer" ("This PC").
I am using the PSP X6 64-bit version on Windows 8.1
I too find it works OK for Collections and also for any folder within Desktop.
I think there must be a bug to do with navigating within "This PC" but there again, PSP X5 SP3 works OK on the same PC.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
kalidor
ram: 8Gb
Post by kalidor »
Thank you all for your suggestions. I have put My Pictures in under Collections and that worked fine.
Must be a software problem as suggested. :D
Tadjio
sound_card: Sound
Post by Tadjio »
Just to confirm, what version of Windows and what version of PSP X6 (64-bit or 32-bit) are you using?
Have you tested the problem in both 64-bit and 32-bit versions?
Tadjio
kalidor
ram: 8Gb
Post by kalidor »
I'm using Windows 7 home. 64bit and also using PaintShop Pro X6 64bit. I haven't tried it with the 32bit.
But at the moment I am happy with having the Pictures in Collection.Thanks for your help.
Tadjio
sound_card: Sound
Post by Tadjio »
kalidor wrote:I'm using using PaintShop Pro X6 64bit. I haven't tried it with the 32bit.
Please could you do a quick test in 32-bit?
I haven't installed it so I can't.
Just open any nested folder, close PSP and re-open PSP to see if the folder sticks.
Tadjio
kalidor
ram: 8Gb
Post by kalidor »
I haven't installed 32 bit either. Sorry
Tadjio
sound_card: Sound
Post by Tadjio »
kalidor wrote:I haven't installed 32 bit either. Sorry
Thanks anyway.
I am just curious to see whether there is a pattern with just 64-bit.
You have Windows 7 and I have 8.1 so it's not that.
Anyone able to test out both 64-bit and 32-bit to see if this issue affects both? - MarkZ?
Tadjio
Tadjio
sound_card: Sound
Post by Tadjio »
By the way, I reported this issue to Corel and they have acknowledged:
Corel wrote:Thanks a lot for reporting this issue. This issue has been put into our bug tracking system.
Tadjio
hartpaul
ram: 8 Gb
Post by hartpaul »
Have just tested with both 32 and 64 bit versions of X6 on Win 7 Laptop and in both cases the My pictures folder was remembered. I do not have the Updates installed - 16.0.0.113
I also changed from one folder in My Pictures to another folder , closed the program both by File > Exit and also the Windows X , and in both cases the last used folder in My pictures was remembered.
MarkZ
ram: 8 GB
Post by MarkZ »
I use Win 7 64 bit, and in both the 32 and 64 versions of PSP the program remembers the last used directory whether it is in computer, collections or file/open. Strange bug.
Mark
