Hi there,
If I have the following:
The Lazy Brown Fox
and needing to show as:
The Lazy
Brown Fox
Do I need to do:
Layer 1 The Lazy
Layer 2 Brown Fox
TIA,
Grazie
Multiple Lines of TEXT done as separate Layers?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Multiple Lines of TEXT done as separate Layers?
No, just hit the "ENTER" or "RETURN" button (whatever it says on your keyboard) to move to the next line just like a regular text editor.
Grazie
- motherboard: Asus TUF X299 MK 2
- processor: Intel Core i9 10900X s2066
- ram: 64gb
- Video Card: EVGA RTX 3080 XC3 Ultra 10GB
For sure, that's what I would have expected, but this is what I get. See BEFORE and AFTER hitting the ENTER/RETURN Key. Is there a "Keep to ONE Line" Control?LeviFiction wrote:No, just hit the "ENTER" or "RETURN" button (whatever it says on your keyboard) to move to the next line just like a regular text editor.
BEFORE: AFTER: Any other suggestions as I am needing to make separate Layers - bit annoying.
Cheers
Grazie
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Check the Leading setting on the Tool Options bar. Make sure it's set to zero.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
- ram: 6 GB
Don't know if it will help or just annoy. xD
I have an old tutorial (made back with version 13 of PSP) - it covers kerning, leading, tracking, and all of the other available text options. It's 10 minutes long but I think I get to those options around minute 8. So you can skip a lot of it if you're not interested.
Part 1 - http://youtu.be/nBMt3zQDJa8
Grazie
- ram: 64gb
Of course, that did it. Set to ZERO and I don't get the Line overlap - I had a MINUS value which X6 was doing exactly what I was asking of it.LindaSue wrote:Check the Leading setting on the Tool Options bar. Make sure it's set to zero.
Thank you,
Grazie
