[solved] cannot undo edits
tedbar123
operating_system: Linux
Post by tedbar123 »
I have been using AFP for a few months without problems, however, as of today I can no longer revert to the original images - Ctl-Shift-R (or right click and select option). If I apply new edits and revert it reverts to the starting point i.e. it reverses all edits made today but not those prior to the problem occurring. If I delete the xmp file I get the original and can edit and revert without problems. Deleting all the xmp file sand re-editing is not an option though.
The system is Opensuse 13.1 x64.
The error log does not report any failure, it simply indicates that the undo was applied.
If I run from the command line no error is reported in the terminal.
I nuked the cache and it rebuilt the images applying the existing xmp files but they still cannot be reverted to the original.
Is there a flag or setting in AFP that is preventing this? That forces a revert to no earlier than a given date?
thanks in advance
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: cannot undo edits
Post by afx »
Are you sure you did not save new defaults?
cheers
afx
tedbar123
Post by tedbar123 »
Wow, that was a quick reply :) Thanks
I considered it as a possibility so went into
Edit-Preferences-reset default files
this made no difference. Is there something else I should check?
The problem is actually worse than I had thought. As long as I don't exit AFP the edits can be undone. If I exit AFP and re-start it the edits cannot be undone.
afx
System_Drive: N/A
Post by afx »
tedbar123 wrote: As long as I don't exit AFP the edits can be undone. If I exit AFP and re-start it the edits cannot be undone.
Could it be that you get CTRL-R and SHIFT-CTRL-R mixed up?
Initial Settings: Settings at start of session (CTRL-SHIFT-R)
Default Settings: Your actual defaults (CTRL-R)
cheers
afx
tedbar123
Post by tedbar123 »
Thanks, was a simple as that :oops:
