Install errors
bz6djs
motherboard: Toshiba
processor: Quad Core
Video Card: Nvidia
sound_card: built in
Hard_Drive_Capacity: 2tb
Monitor/Display Make & Model: 17" toshiba
Corel programs: videostudio 2020, paintshop pro 2021
Install errors
Post by bz6djs »
Hi Guys, I did a review of some of the other installation issues that others have had. Some background:
I am running Windows 8.1 Pro on a Toshiba Qosmio 17" laptop with 16gb ram and quad core processor
Some time back - approx. 2 months ... I pulled down and test corel paintshop x6.
I uninstalled the product before the end of the trial.
I have now come back to the product and purchased it. I had no issue with the trial running (until I uninstalled it intentionally).
Now when I try to install the licensed version (I purchased the video and photoshop software together - video installed no issue and runs) Photoshop gives me an error which is apparently very familiar here on this board....
"You are trying to use a resource on a network drive that is not available".... I have cleaned up all my temp files, rebooted the machine, pointed the machine to the already installed video software (its looking for vc_red.msi on my G: drive) vc_red.msi but nothing works. The error does change when I point it to the video file .. "the file is not a valid installation package".
Not sure where else to look and it appears that Tech Support is now closed until Jan 3... so thought I would ask here to see if anyone has had any success with this issue.
Thanks,
Ron
bz6djs
Video Card: Nvidia
Re: Install errors
Post by bz6djs »
Resolved the issue. In my case it was asking for a fie called vr_cred.msi and it was looking on drive G:
Once I started the install process I searched the computer for the appropriate file (it will extract the file to a temp folder ... not sure why it was search G:<GUID>)
I found several files on my c: drive as mentioned before but none would work. Once I started the install and when it popped up the window saying it could not find the file ...I searched again and it had put the file into the temp dir... once I pointed the install over to that directory the installation complted.
josephlin
Alludo
motherboard: Intel Z490 chipset
processor: Intel Core i9-10900K
ram: 32GB
Video Card: nVidia RTX 2070S
sound_card: Realtek ALC892
Hard_Drive_Capacity: SSD 1TB
Re: Install errors
Post by josephlin »
I'm Joseph who Product Manager of PaintShop Pro. Your install issue seems like is very interesting and we never got the similar one from others. Since you mentioned you ever installed our "trial" version before licensed version installed and I would like to have your help to execute below of cleanup tool again. After that, please try to install your licensed version for seeing if it can resolve your install problem.
https://dl.dropboxusercontent.com/u/613 ... p_v1.2.zip
Good luck and Happy New Year!
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
