help needed desperately.
whenever I try to "create disc' for DVD, immediately VSX6 crashed,
VSXP is version 16.1.0.45
Video properties :
Video type = MPEG-2 Video, Upper field first
Total Frames = 192.396 frames
Attributes = 24bits, 720 x 576; 4:3
Frame rates = 25
Data rate = Variable
Audio properties
Audio type = Dolby digital audio
Total samples = 369,400,320 samples
Attributes = 48000Hz
Layer = None
Bit rate = 256 kbps
Log Name: Application
Source: Application Error
Date: 30-Dec-13 5:58:43 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: USER1.sg.company.com
Description:
Faulting application name: vstudio.exe, version: 16.0.0.0, time stamp: 0x51c07e76
Faulting module name: mfc90.dll, version: 9.0.30729.5570, time stamp: 0x4d2c3758
Exception code: 0xc0000005
Fault offset: 0x000c8e09
Faulting process id: 0x1d48
Faulting application start time: 0x01cf054532b8200b
Faulting application path: C:\Software\X86\MultiMedia\Corel\Corel VideoStudio Pro X6\vstudio.exe
Faulting module path: C:\windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.5570_none_4bf8f87ebf99de1f\mfc90.dll
Report Id: f70c4e74-7138-11e3-9f93-402cf49059f8
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2013-12-30T09:58:43.000000000Z" />
<EventRecordID>225421</EventRecordID>
<Channel>Application</Channel>
<Computer>USER1.sg.company.com</Computer>
<Security />
</System>
<EventData>
<Data>vstudio.exe</Data>
<Data>16.0.0.0</Data>
<Data>51c07e76</Data>
<Data>mfc90.dll</Data>
<Data>9.0.30729.5570</Data>
<Data>4d2c3758</Data>
<Data>c0000005</Data>
<Data>000c8e09</Data>
<Data>1d48</Data>
<Data>01cf054532b8200b</Data>
<Data>C:\Software\X86\MultiMedia\Corel\Corel VideoStudio Pro X6\vstudio.exe</Data>
<Data>C:\windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.5570_none_4bf8f87ebf99de1f\mfc90.dll</Data>
<Data>f70c4e74-7138-11e3-9f93-402cf49059f8</Data>
</EventData>
</Event>
VSX6 is version 16.1.0.45
OS is Windows 7 professional SP1
System
Manufacturer LENOVO
Model 4291HA9
Total amount of system memory 8.00 GB RAM
System type 64-bit operating system
Number of processor cores 2
Storage
Total size of hard disk(s) 289 GB
Disk partition (C:) 8 GB Free (93 GB Total)
Disk partition (D:) 2 GB Free (196 GB Total)
Media drive (G:) CD/DVD
Graphics
Display adapter type Intel(R) HD Graphics Family
Total available graphics memory 1696 MB
Dedicated graphics memory 64 MB
Dedicated system memory 0 MB
Shared system memory 1632 MB
Display adapter driver version 9.17.10.2843
Primary monitor resolution 1366x768
DirectX version DirectX 10
"Create Disc" VSX6 crashed due to mfc90.dll
canuck
Re: "Create Disc" VSX6 crashed due to mfc90.dll
Storage
If those specs are correct then you simply do not have enough free storage space
Thanks for responding.
When I attached a USB HDD and point Working Folder to a directory of this USB HDD, I still get the same error.
I have been having this error for mths already.
BTW, even create disc on SD card also crashed.
Hi Boro
Video Studio effectively uses two working folders
1 / for Capture and Edit timelines, accessed via the Capture Tab or Preferences F6, changing this does not affect the burner module.
2 / the second folder is used for the burner module.
Do Share -- Create Disc – icon lower left Settings and Options – Preferences – or Press F6
This will default to the C: drive until you change it.
Hi lata
thanks for your help.
I have tried setting all working folder to external HDD but still receiving the same error.
I manage to delete enough files to have spare space of 9GB on C drive and 30GB on D drive, but still getting the same error.
BTW, my laptop is on McAfee Endpoint Encryption so spent half a day trying to resize partition but fail.
So last resort try the usual method, uninstall and reinstall VSX6.
After 2 hrs, it works again.
So thanks guys for all your help.
Thanks for the feedback, glad you have managed to get the program working
Happy New year
Happy New year
