Error 5012 while installing Video Studio Pro x6 trial
OKIEWARDOYO
operating_system: Windows 8.1
motherboard: Foxconn G31MXP Socket 775
processor: Intel Pentium Dual Core E5400 2.70GHz
ram: 2GB DDR2
Video Card: SMB1630N 1280x768 60Hz Intel G33 G31 Express Chi
sound_card: onboard
Hard_Drive_Capacity: 320gb
Monitor/Display Make & Model: samsung
Post by OKIEWARDOYO »
I got error 5012 while installing Corel Video Studio Pro X6 trial. I have tried it in many pc, windows 8 32 bit and my own pc windows 8.1 64 bit.
any solution?? :|
http://3.bp.blogspot.com/-8RlRaEXf9w8/U ... r-5012.jpg
OKIEWARDOYO
ram: 2GB DDR2
sound_card: onboard
Re: Error 5012 while installing Video Studio Pro x6 trial
I have just trying on my friends pc some minutes ago (using windows 8 64bit), but same problems i got :'(
Have you tried downloading the trial installation file again. The one you are using could be corrupt...
OKIEWARDOYO
ram: 2GB DDR2
sound_card: onboard
I'm not sure it's corrupted file,
when i clicked on the file , Installation began normally, the bar move normally,, but when it reached -+ 10% of bar's length the problem occured :'(
i attact some of image below:
1. 13seconds after installation began, it says error, can not find init.html
http://3.bp.blogspot.com/-6SfOc9EMneI/U ... t+html.jpg
2. Then, it says can not find FinErr.htm
http://2.bp.blogspot.com/-B-Dk0XXpQ44/U ... rr+htm.jpg
3. And the last, error 5012 displayed
OKIEWARDOYO
ram: 2GB DDR2
sound_card: onboard
Today i have just tried on pc windows 7 32 bit, and i got error like below,
may be i should download trial again,, :'( :cry:
I think that is a good idea. To me, when an installation routine says it can't find a number of essential files, that suggests there is something wrong with the downloaded set-up file(s).
OKIEWARDOYO
ram: 2GB DDR2
sound_card: onboard
I don't know what happened, but has somebody tested this x6 version??
i have spent couple of hours donwloading again this x6 version today,
then i try to install and the problem still occured,, i'm using Windows 7 32 Bit now,,,
the screenshot is below,
this is same as my first download couple of days ago :'(
any help??
Screenshot:
I donwload using Internet Donwload Manager (IDM), i'm sure some bugs in X6 Installer :(
The first process the installer goes through is to extract the setup files to:-
C:\Program Files (x86)\Corel\Corel VideoStudio Ultimate X6 Setup Files
This is failing, the program has not started the installation.
Delete the folder \Corel VideoStudio Ultimate X6 Setup Files
Then try running the VSX6_Pro_TBYB.exe again.
Right click the file and Run as Administrator.
By the way my trial version VSX6_Pro_TBYB.exe is 1,380,868Kb
hope this helps
OKIEWARDOYO
ram: 2GB DDR2
sound_card: onboard
Ok, i will try, i hope it works
OKIEWARDOYO
ram: 2GB DDR2
sound_card: onboard
lata wrote:Hi
hope this helps
I have tried your suggestion but it still same, error occured,
plese see this video
http://www.youtube.com/watch?v=5CdfsdVB ... e=youtu.be
I think, at first double click, this corel installer trying to extract and copy all nessesary file to my c:/Program Files (x86)/Corel/Corel Video Studio X6/
but, the setup.exe ( on c:/Program Files (x86)/Corel/Corel Video Studio X6/setup.exe) run immmediately before extracting finish.
i don't have any idea
Have you tried extracting the files to a different location, sorry yes as you tried Windows 7, just a thought.
can you create a new user account having Administrator rights.
Then try installing using the new account.
If successful you can delete / remove the new account.
OKIEWARDOYO
ram: 2GB DDR2
sound_card: onboard
Yes, you can see on my video above,
ok, i will try your suggestion and tell the result later, ,
