I understand many of the aspects of color management: gamut, color space, profiles, calibration, and most of the accompanying pieces. The problem is that I don't understand the inter-relationships of the various steps between taking a photo and printing it.
My equipment is not wonderful. If I were serious, I would have spent 10x what I did; but I'm not a pro. I'll settle for the best I can squeeze out of it. My goal, at this point, is to get my prints to look like what's on the screen.
For software I am using PSP X6 and Windows 8.1.
- The photos I get come from various sources. As I understand it, those images (primarily JPEG if they come from a camera, presumably RAW if I scan directly into PSP) should have the profile of the capturing device embedded in them. Is that correct?
- In the past I've been told that I should always use the color management in my editing application, rather than whatever Windows makes available. Is that still true? So far as I can tell, there is no way to turn off Windows Color Management (WCS).
- You can turn off color management in PSP. There is a checkbox for it.
- I've been reading that I should set my PSP color working space to sRGB. Is that turned on and off by the color management checkbox? Assuming I have a profile for my capture device (camera or scanner), should I use that profile instead?
- I have factory supplied profiles for both my monitor and my printer. Supposedly the printer will automatically select one of its various profiles based upon the paper I use, but that's a setting in WCS. (I can force a particular profile if I want.) In PSP's color management, I have to pick the profile manually.
- Should I turn off color management in PSP, and set everything up in WCS?
- WCS has a setting for viewing conditions. The default is "WCS profile for sRGB viewing conditions", the alternative is "WCS profile for ICC viewing conditions". Does that mean that I could (or should) get an ICC profile based upon my work area's lighting, etc.? How would I do that?
Thanks to anyone who can help, or who can refer me to a cogent discussion of this on the web. I've read everything that's on the Microsoft sites, but while that's very good at explaining "what" I didn't get much on "how" or "why".
