Send files to batch hangs ASP
t3mujin
operating_system: Linux
motherboard: Asus P5QL-E
processor: Core2 Quad CPU Q6600 2.40GHz
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: HP LP2475W
Post by t3mujin »
I'm having an issue when exporting an image to jpeg: the output batch hangs and after a some minutes I always have to kill ASP. The difference with this image with all the others is the amount of layers, around 30 (the sensor was very dirty...). Any of you guys experienced it and have some solution or workaround?
By the way, the only workaround for now is to export the image without the layers and remove the spots with Gimp
mikmak
Re: Send files to batch hangs ASP
Post by mikmak »
I have the same problem and have installed the old 1.0.1.10 version and here it works fine.
Regards
M
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
30 layers or 30 regions in the heal/clone layer?
Do you have OpenCL active? If yes turn it of.
cheers
afx
t3mujin
Post by t3mujin »
afx wrote:30 layers or 30 regions in the heal/clone layer?
cheers
afx
Sorry for the confusion, it's 1 layer with 30 regions. I already have OpenCL turned off.
peteln
motherboard: Magic-pro
processor: AM64x2
ram: 3GB
Video Card: Nvidia GTX275
sound_card: on board
Post by peteln »
It seems to me that ASP doesn't handle cloning very efficiently.
I experienced similar issue with dirty images produced by D600 previously (now the sensor is much cleaner after shutter replacement). The program didn't hang, but took a few minutes to complete the conversion if extensive cloning was performed.
t3mujin
Post by t3mujin »
I guess I'll stick with my workaround for more problematic images: sent them to Gimp and fix them there.
