Join projects
sylwester
Join projects
Post by sylwester »
I try to join 3 projects to make a biger one.
I cann'y found the way.
Who can help me ?
regards
Re: Join projects
Post by BrianCee »
In order to get more than one project in the timeline you must first put them into a library pane.
Open a library and click on the "Import Media Files" icon (looks like a little folder in the top left corner) - then browse to your .vsp files - select them and click 'open' then they will appear in the library.
Now you can drag the thumbnails for the projects down into the timeline in what ever order you want - now go to "Share" and either create a video or Create a DVD of your three projects as one.
sylwester
Re: Join projects
Post by sylwester »
thanks for the answer. This way I know.
In this method VSP camming as a video file ( cannot edit...) but I need put in time line all delails to make some correction.
Re: Join projects
Post by BrianCee »
cannot do - you can only have one project open for editing at a time.
you need to edit each project individually before putting them all together
Re: Join projects
Hi sylwester
There may be a way………
First make a copy of your VSP project files so you can revert to the originals if needed.
There is a workround that will allow you to add the project, you have first to create an Instant Project of the project.
I would suggest using the smallest project.
Open the smallest project and choose File -- Export as Template this will create an Instant Project available from the library.
Open your target project , access the Instant Project Library – Custom page and Add your new template, Beginning or End
sylwester
Re: Join projects
Post by sylwester »
Thanks. It will be work
