I'm using Aftershot Pro 1.2.0.7 on Ubuntu 13.10 (AMD64) and an Ivy Bridge i7 with integrated GPU (and an Nvidia K1000M which is not enabled). My camera is a Canon 6D. I'm shooting medium-size RAW.
Everything was working fine in the beginning, but after doing *something* (editing an image, browsing the catalog, can't remember exactly what), some images can't be edited anymore. The preview and thumbnails are visible, but there's no histogram and none of the image controls work. If I play around with them long enough, instead of the image there's a grey rectangle containing the text "No Image Available".
I tried to recreate the catalog. No improvement.
Running the program in the console produces the following:
Install Path: /opt/AfterShotPro
LD_PATH: /opt/AfterShotPro/lib:
XLIB_SKIP_ARGB_VISUALS: 1
0.11: I have SSE2
0.239: KDE4 plugin path removed from the application's library path.
1.48: Bibble program arguments ("./AfterShotPro")
1.118: Loaded "/opt/AfterShotPro/supportfiles/locale/aftershot_en.qm"
1.141: Loading plugins
1.623: asGPSplugin::init
2.292: Initialising Wavelet Denoise 2 filter
2.367: Warning: slow tiles used because plugin is not white listed: "WaveletDenoise2"
2.569: Initialising Wavelet Sharpen 3 filter
2.746: Warning: slow tiles used because plugin is not white listed: "WaveletSharpen2"
3.716: AfterShot2 Pro key used. 7
3.752: System locale: en_US
3.861: Added plugin locale file: "/home/sorin/.AfterShotPro/Plugins/asGPS.afplugin/locale/asGPS_en.qm"
3.877: Loaded "/opt/AfterShotPro/supportfiles/locale/aftershot_en.qm"
3.883: Loaded "/home/sorin/.AfterShotPro/Plugins/asGPS.afplugin/locale/asGPS_en.qm"
5.600: AfterShot2 Pro key used. 7
5.813: AfterShot2 Pro key used. 7
5.878: AfterShot vers.: 1.2.0.7
5.882: Built on: "Fri Jun 28 2013"
5.882: Language: en
5.882: App Path: /opt/AfterShotPro/bin/AfterShotPro
5.883: System Home: ../supportfiles
5.883: User Home: /home/sorin/.AfterShotPro
5.884: Prefs Home: /home/sorin/.config/Corel/AfterShot Pro.conf
5.884: Platform: Linux
5.891: Issue: "Ubuntu 13.10 \n \l"
5.893: Kernel: "Linux version 3.11.0-14-generic (buildd@allspice) (gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu8) ) #21-Ubuntu SMP Tue Nov 12 17:04:55 UTC 2013"
5.893: Build Mode: Release
5.893: Product Name: "AfterShot Pro"
5.893: AfterShot2 Pro key used. 7
5.893: Registered Version
5.896: AfterShot2 Pro key used. 7
5.899: Initializing
5.914: Cpu Manager init: 8
5.917: **** Making CLManager
5.920: Got 0 platforms
5.920: OpenCL is disabled in low mem mode
5.929: "Could not select an OpenCL platform"
5.931: **** CLManager not initialized
5.931: tileSize: 256
5.936: "MemTotal: 8045620 kB"
5.938: Memory: 3
5.938: ====================================================
5.939: BImageTile: 1800 purge
5.939: ====================================================
5.939: BTiledImage: 2147483647 purge
5.939: RegionImageTile: 3000 purge
5.940: TileStack: 24 purge
5.940: TileStack: 12 cache (12 min)
5.940: ====================================================
5.940: StackTile: 3000 purge
5.942: Created 226 buffers of 857472
5.944: FALLBACK to 452 tiles
5.944: ====================================================
5.954: PerfectlyClear: 6 purge
5.954: PerfectlyClear: 4 cache (4 min)
5.954: ====================================================
5.956: Version: 600 purge
5.956: Version: 300 cache (50 min)
5.956: ====================================================
5.957: UncompressedRawData: 9 purge
5.957: UncompressedRawData: 9 cache (8 min)
5.957: ====================================================
5.958: RawData: 25165821 purge
5.958: ====================================================
5.960: Path: 2147483647 purge
5.960: Path: 2147483647 cache (2147483647 min)
5.960: ====================================================
5.961: NContainer: 2147483647 purge
5.961: ====================================================
5.962: ImageMaster: 600 purge
5.962: ImageMaster: 300 cache (50 min)
5.963: ====================================================
5.964: PluginData: 9 purge
5.964: PluginData: 9 cache (8 min)
5.964: ====================================================
5.965: Histogram: 24 purge
5.965: Histogram: 12 cache (12 min)
5.965: ====================================================
5.966: NoiseEngine: 150 purge
5.966: NoiseEngine: 75 cache (50 min)
5.966: ====================================================
5.966: Asset: 2147483647 purge
5.966: Heavy Asset: 2147483647 purge
5.976: Allocate Asset manager
5.991: asGPSplugin::registerOptions
6.44: Option group - "" - already contains an option with name - "TIFFTAG_AFMODE"
6.44: Option was not registered.
6.45: Option group - "" - already contains an option with name - "TIFFTAG_FLASHMODE"
6.45: Option was not registered.
6.48: Globals: systemhome ../supportfiles
6.48: Globals: userhome /home/sorin/.AfterShotPro
6.53:
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Identifier: de.schrell.asGPS
Version: 1.4.1
Path: <User Home>/Plugins/asGPS.afplugin
Identifier: com.roland65.USM
Version: 0.6.0
Path: <User Home>/Plugins/USM.afplugin
Identifier: com.corel.vigne
Version: 1.1.0
Path: <User Home>/Plugins/Vigne.afplugin
Identifier: sph.waveletdenoise
Version: 0.31.0
Path: <User Home>/Plugins/Wavelet Denoise.afplugin
Identifier: sph.waveletsharpen
Version: 1.34.0
Path: <User Home>/Plugins/Wavelet Sharpen3.afplugin
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <System Home>/plugins/Equalizer.afplugin
Identifier: com.SMP.Nostalgia
Version: 1.0.8
Path: <System Home>/plugins/Nostalgia.afplugin
6.291: LensDB inserting camera Sony a37 failed
6.308: LensDB inserting camera Panasonic Micro 4/3 DMC-GF3 failed
6.308: LensDB inserting camera Panasonic Micro 4/3 DMC-GF5 failed
6.364: /home/sorin/.AfterShotPro/bibbledebug
6.471: AfterShot2 Pro key used. 7
6.497: Creating main window
6.523: AfterShot2 Pro key used. 7
6.525: Starting Catalog Manager
6.547: New Io Asset Mananager
6.627: DB 0 at version 20
6.765: Locking catalog: "/home/sorin/.AfterShotPro/cache"
6.798: Locking for station: "{341c0fef-69e3-5144-9acf-35a1fb0ef3c5}"
6.843: Opening DB "/home/sorin/.AfterShotPro/cache"
6.887: DB 1 is already up to date
7.13: AfterShot2 Pro key used. 7
7.49: Scheduled Cache Cleaning
7.154: CacheReducer removed 0 versions due to age older than QDateTime("Wed Dec 4 17:36:09 2013")
7.157: Starting cache cleanup
7.177: Finished cache cleanup
7.181: Locking catalog: "/home/sorin/Pictures/AfterShot Pro Catalogs/Thai2013"
7.182: Locking for station: "{341c0fef-69e3-5144-9acf-35a1fb0ef3c5}"
7.204: Opening DB "/home/sorin/Pictures/AfterShot Pro Catalogs/Thai2013"
7.246: DB 2 is already up to date
7.362: AfterShot2 Pro key used. 7
7.395: Starting Asset Manager
7.401: AfterShot2 Pro key used. 7
7.407: Starting Memory Manager
17.176: AfterShot2 Pro key used. 7
17.723: AfterShot2 Pro key used. 7
17.764: AfterShot2 Pro key used. 7
17.768: AfterShot2 Pro key used. 7
17.781: AfterShot2 Pro key used. 7
17.782: AfterShot2 Pro key used. 7
17.783: AfterShot2 Pro key used. 7
17.784: AfterShot2 Pro key used. 7
17.801: Trying to set queue hotkey "T" for queue "16-bit TIFF"
17.803: Trying to set queue hotkey "8" for queue "8-bit TIFF"
17.803: Trying to set queue hotkey "D" for queue "Download"
17.803: Trying to set queue hotkey "F" for queue "JPEG Full Size"
17.803: Trying to set queue hotkey "J" for queue "JPEG Proof"
17.804: AfterShot2 Pro key used. 7
29.671: Trying to set copyset shortcut "Ctrl+8" for "Color Correction"
29.688: Trying to set copyset shortcut "Ctrl+9" for "Exposure"
29.688: Trying to set copyset shortcut "Ctrl+3" for "GPS Settings"
29.688: Trying to set copyset shortcut "Ctrl+4" for "IPTC Photographer's Details"
29.689: Trying to set copyset shortcut "Ctrl+1" for "Metadata and IPTC"
29.689: Trying to set copyset shortcut "Ctrl+2" for "Metadata, IPTC, and GPS"
29.734: Registering AfterShot plugin... "BibbleBuiltin"
29.748: Registering AfterShot plugin... "Equalizer"
29.768: Registering AfterShot plugin... "Nostalgia"
29.769: Registering AfterShot plugin... "BlackAndWhite"
29.770: Registering AfterShot plugin... "WaveletSharpen2"
29.770: Successfully registered "WaveletSharpen2_LLorens_Filter" filter
29.770: Successfully registered "WaveletSharpen2_USM_Filter" filter
29.770: Successfully registered "WaveletSharpen2_Wavelet_Filter" filter
29.770: All Wavelet Sharpen 3 Filters enabled
29.772: Registering AfterShot plugin... "WaveletDenoise2"
29.772: Successfully registered Wavelet Denoise 2 filter
29.772: Registering AfterShot plugin... "Vigne"
29.773: Registering AfterShot plugin... "USM"
29.778: Successfully registered USM filter
29.781: Registering AfterShot plugin... "asGPS"
29.781: asGPSplugin::registerFilters
29.781: asGPSplugin::finish
29.805: asGPS: ConfigurationMapper
30.24: 0 : "UncompressedRawData"
30.26: 1 : "RawNoise"
30.27: 2 : "Demosaic"
30.28: 3 : "TiffSrc"
30.28: 4 : "JpegSrc"
30.28: 5 : "Mip"
30.29: 6 : "PreScalingFilter"
30.29: 7 : "CameraRgbToWorkingspace_Rendered"
30.29: 8 : "CloneLayer"
30.30: 9 : "HealRendererFilter"
30.30: 10 : "Highlights"
30.30: 11 : "NoiseNinja"
30.30: 12 : "SpatialDistortion"
30.30: 13 : "Positive Vignette"
30.31: 14 : "Mirror"
30.31: 15 : "Crop"
30.31: 16 : "WhiteBalance"
30.32: 17 : "AutoLevel"
30.32: 18 : "Exposure"
30.32: 19 : "FillLight"
30.32: 20 : "CameraRgbToWorkingspace_Raw"
30.34: 21 : "WaveletDenoise2Filter"
30.34: 22 : "WaveletSharpen2_LLorens_Filter"
30.34: 23 : "WaveletSharpen2_USM_Filter"
30.35: 24 : "WaveletSharpen2_Wavelet_Filter"
30.35: 25 : "USMFilter"
30.35: 26 : "Sharpen"
30.36: 27 : "Invert"
30.36: 28 : "PerfectlyClear"
30.36: 29 : "Color"
30.37: 30 : "SelectiveColor"
30.37: 31 : "EqualizerFilter"
30.37: 32 : "RgbToLab"
30.38: 33 : "LabToRgb"
30.38: 34 : "NostalgiaFilter"
30.38: 35 : "BlackAndWhiteFilter"
30.39: 36 : "Curves"
30.39: 37 : "VigneFilter"
30.39: 38 : "Negative Vignette"
30.39: 39 : "WorkingToMonitor"
30.40: 0 : "VersionStackSrc"
30.40: 1 : "PostImage"
30.40: 0 : "JpegSrc"
30.40: 1 : "Mip"
30.40: 2 : "WorkingToMonitor"
30.171: asGPSplugin::toolWidgets
30.175: asGPSplugin::toolFiles
89.423: asGPSplugin::toolWidgetCreated
89.430: asGPS: external map window created.
89.514: asGPS: updateMapUrl = "qrc:///html/asGPSmap.html?toolsMap=true"
89.540: asGPS: updateMapUrl = "qrc:///html/asGPSmap.html?toolsMap=false"
89.541: asGPS: handleIptcCB 1
89.541: asGPS: handleCoordsCB 1
90.316: AfterShot2 Pro key used. 7
90.319: Ready
90.423: asGPS: load finished true
90.463: asGPS: load finished true
90.728: Initializing file system view...
90.739: File: s: 33
90.743: File system view initialized.
90.766: Container __CATALOG_ROOT__/assets
90.850: Container __CATALOG_ROOT__/assets/home
90.935: File does not exist or could not be opened: "/home/sorin/.AfterShotPro/slideshow.xmp"
90.935: No custom slideshow settings found
91.803: MultiImageView::doCursor() Invalid cursor mode
91.810: Container __CATALOG_ROOT__/assets/home/sorin/Pictures/2013.11.09. tailanda/sorin/cr2
91.838: Container __CATALOG_ROOT__/assets/home/sorin/Pictures/2013.11.09. tailanda/sorin
91.839: Container __CATALOG_ROOT__/assets/home/sorin/Pictures/2013.11.09. tailanda
91.844: Container __CATALOG_ROOT__/assets/home/sorin/Pictures
91.846: Container __CATALOG_ROOT__/assets/home/sorin
91.873: set sort order ascending
91.900: File: s: 4
91.905: File: s: 19
91.908: File: s: 7
91.916: File: s: 3
91.917: File: s: 5
91.920: Container __CATALOG_ROOT__/assets
91.922: viewmode: 1
92.949: Opening DB "/home/sorin/Pictures/AfterShot Pro Catalogs/Thai2013"
93.3: Opening DB "/home/sorin/Pictures/AfterShot Pro Catalogs/Thai2013"
93.10: Opening DB "/home/sorin/Pictures/AfterShot Pro Catalogs/Thai2013"
93.81: asGPSplugin::webInfosReady: "de.schrell.asGPS" "1.4.1"
93.691: JavaScript: "TypeError: Result of expression 'style_orange.clone' [undefined] is not a function." line: 41 source: "qrc:///html/asGPSol.js"
93.692: JavaScript: "TypeError: Result of expression 'style_orange.clone' [undefined] is not a function." line: 41 source: "qrc:///html/asGPSol.js"
93.840: JavaScript: "defPro = EPSG:4326 / mapPro = EPSG:900913" line: 3 source: "qrc:///html/asGPSol.js"
93.841: JavaScript: "center = lon=0,lat=-7.081154550627918e-10" line: 3 source: "qrc:///html/asGPSol.js"
93.955: JavaScript: "defPro = EPSG:4326 / mapPro = EPSG:900913" line: 3 source: "qrc:///html/asGPSol.js"
93.956: JavaScript: "center = lon=0,lat=-7.081154550627918e-10" line: 3 source: "qrc:///html/asGPSol.js"
94.56: VersionPreviewJpegAsset::run() - unable to open file "/home/sorin/Pictures/AfterShot Pro Catalogs/Thai2013/assets/home/sorin/Pictures/2013.11.09. tailanda/sorin/cr2/.cache.noindex/{758ff29a-4157-144c-a455-42d85935c3e3}.prv.noindex"
94.70:
asGPSplugin: handleHotnessChanged
94.70: asGPS: HHC "" true
94.71: asGPS: updateUI
96.16: Extracting RAW data: "/home/sorin/Pictures/2013.11.09. tailanda/sorin/cr2/IMG_0421.CR2"
96.188: Decoding RAW data: "/home/sorin/Pictures/2013.11.09. tailanda/sorin/cr2/IMG_0421.CR2"
97.358: "BError: type = 1014, "CameraReader::jhead::getbithuff: Error, corrupt data in lossless jpeg stream." in file ../src/CameraReader.cpp:1640"
98.708: Decoding RAW data: "/home/sorin/Pictures/2013.11.09. tailanda/sorin/cr2/IMG_0421.CR2"
99.472: "BError: type = 1014, "CameraReader::jhead::getbithuff: Error, corrupt data in lossless jpeg stream." in file ../src/CameraReader.cpp:1640"
