Hello,
I just ran into a problem, using Videostudio X5 Ultimate. When i try to import a .PNG-image with a transparent background, but then
the background of the imported image turns black.
However, when i open the same image in an image-viewer, the background actually is transparent.
Does anyone has experience on this?
Kind regards from The Netherlands!
My transparent .PNG background turns black.
Wouterj1993
- processor: Intel i5 M460
- ram: 4GB
- Hard_Drive_Capacity: 120GB SSD
- Monitor/Display Make & Model: 1920x1080, 60Hz Digital LCD-screen
Re: My transparent .PNG background turns black.
Hello
i don't know about turning black - many users have complained about it being white and not transparent - the usual reason for that is that the .png does not have a 32bit image depth - to be transparent in VideoStudio make sure your transparent .png's are 32 bit depth.
But also where are you putting the .png - if you are putting it in the top video track then the black preview window background will show through - it needs to be in an overlay track with a video or image in the top track
to test please download and unzip the attachment here and you should then have a transparent .png - put it in an overlay track and see if you can see through it.
Wouterj1993
- ram: 4GB
Thanks for the quick reply. Searching for an answer i did review the image's properties, and it said the image depth is only 8-bit.
I'll try some testing with your supplied file and post the results. Besides, do you have any tip in changing/converting the image depth?
Kind regards.
Kind regards.
I use a non-Corel photo/image manipulating package which allows me to save images at a variety of bit depths
this short video here will show how I make transparent png's - http://www.youtube.com/watch?v=6-STYhTXDBE
Wouterj1993
- ram: 4GB
In the meanwhile, i've tested the given image concluding it works like a charm. I put it in an overlaytrack with another image in the 'main'-track and
saw right through the meant-to-be-transparent part of the given image.
Right now i use Vectormagic Desktop Edition to add a transparent part to my image. At the end of the wizard of that program i can save the image as .png and when
i check the properties it says it is 32 bit. However, it still comes up in VSx5 with the transparent parts blackened...
don't know Vectormagic I'm afraid but it sounds as though your problem lies with how it produces transparent png's - you need to experiment with settings in it - or try another programme.
