How can I remove sound from from .mpg movies
HarryNot Potter
motherboard: MSI 770-C45
processor: AMD Sempron 145
ram: 8 GB
Video Card: ASUS EAH5450Silent DI 512MD2 LP SN B3C0YZ141361
sound_card: Sound Blaster Audigy SE Model SB0570
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Samsung T260
Post by HarryNot Potter »
I have a bundle of .mpg movies with unwanted sound included. Can I remove it?
Background: Took a bunch of ancient 8mm movies to a store and had them put on a CD. They came back in sets of .bup, .ifo, and .vob files. VideoStudio Pro X6 inducted them as .mpg files. VS was recently bought in a box; allowed update after installation. I have no idea how to check the version.
Re: How can I remove sound from from .mpg movies
Post by BrianCee »
Yes of course you can remove the sound - and replace it with any sound or music of your choice.
Put your mpeg file in the top video track - right click over it and choose "Mute" from the pop-out - that will remove the sound - if you want to then add sound to one of the audio tracks - now you MUST go to "Share >> Create Video File >> DVD >>?? " to render out a new mpeg video without the original sound.
Videostudio X6 currently only has one update pack - to check the version number first click on the round orange icon with the downward pointing arrow up in the top right corner - this will open the corel guide - in the top right corner of that window click on the two little gear wheels - and choose "about Corel Videostudio X6" then another window opens and under the bottom left corner you should see "16.1.0.45" - the 1 tells you that SP1 is installed - a 0 there says it is not.
