I recorded a Script in X6. It runs fine until it uses Topaz Plug-In "Clarity". After I make the adjustments in Clarity and click "OK", the screen goes back to PSP as it should but then a get an error message from Windows as follows:
Corel PaintShop Pro X6 (64 bit) has stopped working.
A problem caused the program to stop working correctly.
Windows will close the program and notify you is a solution is available.
If I manually go through the exact same steps in PSP all the steps work fine. It's just when I run the steps as a Script that this fails.
Does anyone have any suggestions? I'd greatly appreciate your input.
Thanks,
Vinny
Script Failure
vciro
- motherboard: ASUS P6X58D-E
- processor: INTEL Core I7 3.33 GHz
- ram: 12 Gig
- Video Card: NVIDIA GeForce GTX 580
- Hard_Drive_Capacity: 2600.18 Gi
- Monitor/Display Make & Model: Samsung SMB2330H
Script Failure
Semper Fi,
Canon Rebel 450d
PSP X6
Canon Rebel 450d
PSP X6
OldRadioGuy
- motherboard: Dell 0YJPT1 A00
- processor: Intel Core i7-3770 3.40 GHZ 8 virtual cores
- ram: 16 GB
- Video Card: AMD Radeon HD 7770
- sound_card: Realtec High Definition Audio
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Samsung 23" HD 1920x1080 px
Re: Script Failure
Vinny, I tested both Clarity and Adjust in PSPX6 in x64 and x32 scripts and get the same crashes.vciro wrote:I recorded a Script in X6. It runs fine until it uses Topaz Plug-In "Clarity". After I make the adjustments in Clarity and click "OK", the screen goes back to PSP as it should but then a get an error message ...
Thanks,
Vinny
I don't think PSP scripting has kept up with the evolution of 8bf plugins. But the question: Is this a PSP problem or one caused by the Topaz plugin? Did you report this problem to the folks at Topaz Labs? I think your chances of getting a response there are pretty good. Perhaps not a solution, but an explanation, at least.
In recent years I have resorted to use of another editor for running macros with Topaz plugins. But it, too, has had problems with some of the newer plugins.
Bob
Affinity Photo 1.5 | ON1 Photo RAW 2017 | DxO Optics Pro 11 | Aftershot Pro 3 | Olympus PEN-F cameras
vciro
- ram: 12 Gig
Re: Script Failure
OldRadioGuy wrote:Vinny, I tested both Clarity and Adjust in PSPX6 in x64 and x32 scripts and get the same crashes.vciro wrote:I recorded a Script in X6. It runs fine until it uses Topaz Plug-In "Clarity". After I make the adjustments in Clarity and click "OK", the screen goes back to PSP as it should but then a get an error message ...
Thanks,
Vinny
Bob
Thanks very much, Bob. I'll report it to Topaz and see what happens.
Vinny
Semper Fi,
Canon Rebel 450d
PSP X6
Canon Rebel 450d
PSP X6
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Script Failure
Is this the only Topaz Plugin you have?
Have you tried scripting other plugins? Plugins directly from Topaz and plugins from other producers?
It helps to determine if there is a bug in scripting, or if it's a bug with how plugins work. Or a mixture of the two.
OldRadioGuy
- ram: 16 GB
Re: Script Failure
PSP had problems running several Topaz plugins in scripts at least a couple of versions ago. I reported the bugs to both Corel and Topaz. Topaz Adjust was one that worked in PSP back then. The problem was never resolved to my satisfaction.
The newer Topaz plugins like Clarity, the latest version of B&W Effects, Detail and ReStyle are more complex and have created challenges for a competitor, PhotoLine, which had been running previous Topaz plugins in recorded actions very easily. This complexity seems to be occurring in plugin development by other companies, too. (We can thank Adobe Photoshop and Adobe's Lightroom for that.) If you look inside the installed folders for many of these newer plugins, you'll often find two pairs of plugins (plus a standalone) -- a standard and an automated -- each in x32 and x64 versions. The latest version of PhotoLine has addressed this problem by providing a way to call the .EXE standalone files for plugins that have them. Thus, in that program, Topaz Labs' photoFXlab, which serves as manager for the plugins, now enables use of all Topaz plugins in PhotoLine.
Since we had a PSP script for running the standalone of Color Efex Pro uploaded to this board recently, I would assume one could be written to accommodate photoFXlab, thus enabling use of any Topaz plugin in PSP that way.
Topaz Labs used to offer a free runtime wrapper that allowed Lightroom to run their plugins, but I don't find it on their site anymore.
Bob
Bob
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Script Failure
Like Bob, I too had an issue with Adjust 5 in scripts. Adjust 5 works fine on it's own in PSP (various versions including X6) but not in scripts. However, the older version of the plugin, Adjust 4, works fine in scripts.
I reported this way back when but since it's not something that I use often and I have a workaround (Adjust 4) I just live with it.
vciro
- ram: 12 Gig
Re: Script Failure
I spoke with the folks at Topaz. They agree it is a problem and have slated it for a future fix. That would be nice
Vinny
Vinny
Semper Fi,
Canon Rebel 450d
PSP X6
Canon Rebel 450d
PSP X6
