Cassel wrote:I am not intending to only compare with PS but with PSE too. I was told that PSE does not even have native vector functions (so things like text on path is not possible natively). This is something I was told as I have no experience with PSE even if I have a copy. So this is what I want to showcase: what PSP can do.
While it is true that PSE does not have the same flexible vectors that PSP does, it does have paths and text.
PSE does not have the same vector abilities as PSP but it can do a lot of the same things in different ways if you know how. Text on a curve for example, PSE actually has several text tools. Some for just regular text, others for text as a mask, and still another for text on a path. Where the path and the text both remain editable.
It also has vector shapes that you can use. Though I haven't seen the ability to make your own custom shapes.
So it's a lot more structured, one of the issues I always had with PSE is that while you can do a whole lot with it, they seemed to always add very special tools so things were highly specialized. You didn't gain the same flexibility. But that hasn't stopped it from being powerful.
A
PSE does have a color curves adjustment. But it's specifically for brightness and contrast of the whole image, focusing on midtones, highlights, and shadows. So definitely not the same as Curves. Maybe PSP's histogram adjustment would be closer.
How far are we willing to take what can and cannot be done between PSP? I'm assuming you want to keep it native. As plugins and scripts can bring a lot to both that aren't normally included anyway. For example ElementsXXL can bring a whole slew of new adjustment layers and tools to Elements including commands like Curves. Same with a software called Elements +.
Having never looked into it myself, I had heard that through Actions it was possible to get Elements to use Photoshop's curves tool because it still existed in the code even though it wasn't included in any menu. Don't know if that's still true.
Same with PSP. Provided Corel keeps releasing KPT the Gradient Lab could be used to create a gradient map. Same could be said for scripting.
