I installed PSP x6 ultimate using the install 32 and 64 bit versions. I tried to install the kpt and creative content and get the following message-"setupnew\setup.cpp(143)
PAPP:
PVENDOR:
PGUID:
$15.0.0.498
@windows vista service pack 1 (7601)
IE version:9.11.9600.16428"
I also get the same error message using the 2nd dvd to install "perfectly clear" and "ultimate creative content".
I am running windows 7 pro and don't know why I am getting the error messages. Could this be because they do not run on the 64bit versions? If so when asked to install both versions would they run. There is no program start application for the 32 bit version even if you select install both.
I sent an email to support using my code, but they are clueless.
Mike
Error installing creative content and KPT
mikesteven
- motherboard: Biostar P4M90-M4
- processor: 2.4
- ram: 4gb
- Video Card: nvidia geforce 9500
- sound_card: on board
- Hard_Drive_Capacity: 500gb
- Monitor/Display Make & Model: viewsonic vx2739wm
josephlin
- Alludo
- motherboard: Intel Z490 chipset
- processor: Intel Core i9-10900K
- ram: 32GB
- Video Card: nVidia RTX 2070S
- sound_card: Realtek ALC892
- Hard_Drive_Capacity: SSD 1TB
Re: Error installing creative content and KPT
Have you installed AntiViru program on your system? If you had it, please disable the "Auto Scan" function and then install your content again. Or give a trying as below.
1. Disable your Antiviru program if you had installed.
2. Insert 2nd disc and copy "PerfectlyClear" folder from disc to HDD.
3. Install "Perfectly Clear" through HDD.
The error message you provided seems like is the installer file isn't completed. Please have a trying and update the result. Thx.
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
