A question - Lately ASP has been very slow loading a file. From the time I select the Raw file in a folder to the thumbnail actually appearing in the side bar is about 20 seconds. If I select multiple files then it's 20 seconds to the first file then as per normal after that.
Any ideas on what has changed or how I can speed it up?
Regards
Slow loading
brucet
Re: Slow loading
So either no one has this problem and I'm on my own. Or everyone has this problem and doesn't have a solution!!
regards
regards
jknights
- motherboard: Apple
- processor: Intel 3.08GHz Dual processor Quad Core
- ram: 24GB
- Video Card: ATI Radeon X1600
- sound_card: Intel HDA
- Hard_Drive_Capacity: 6TB
- Monitor/Display Make & Model: Apple Display
Re: Slow loading
Have you tried starting up ASP with the Shift key held down. This flushes the cache AFAIR.
Still learning after all these years!
brucet
Re: Slow loading
Thanks. It is a cache problem. But unless I Shift key while opening or set the cache clean to every session it bogs down big time.
regards
regards
