Remove text from image
spk8198
Post by spk8198 »
With PaintShop Pro x6, is there a way to remove text from a shirt in the image and get the entire shirt one solid color? The shirt in the photo is not flat, it is wavy.
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Remove text from image
Post by Kathy_9 »
There is no "one step fix" if that's what you are asking. If you have a decent resolution image and some patience it can be done (probably with the clone tool) but it would be helpful to see the image prior to suggesting a method.
spk8198
Post by spk8198 »
Here is a crop of the image showing what I am talking about along with information on the photo. It is pretty hard to tell what is going on. I couldn't upload as much as I wanted as there is a pretty small attachment size allowed, but where the M and N are there are waves in the shirt.
Dimensions: 4028 x 6080 pixels
Date: 2013:09:19 11:43:41
Camera: NIKON CORPORATION NIKON D600
Exposure: 0.033 sec (1/30)
Aperture: f/2.8
Focal Length: 50 mm
ISO Speed: 1250
Flash Used: No
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
To post a larger sample I suggest you crop a suitable area from your photo, enough to demonstrate the issue, crop as new image, resize the new image to the max pixel size allowed for posting (850 x 800?) save under a new name and upload that. I think cloning would work but it would take quite a bit of work to make it look real.
Mark
spk8198
Post by spk8198 »
Here is a new crop of the image.
Grazie
motherboard: Asus TUF X299 MK 2
processor: Intel Core i9 10900X s2066
ram: 64gb
Video Card: EVGA RTX 3080 XC3 Ultra 10GB
Post by Grazie »
I used X6 and "Clone Brush". I kept taking nearby samples and changing Brush size. In the more complex wavy areas I made adjustments to density and just kept brushing over and over until I had a good enough meld into the surrounding areas.
Doesn't look too shabby?
http://forum.corel.com/EN/download/file ... ew&id=4729
Grazie
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
Grazie wrote:I used X6 and "Clone Brush". I kept taking nearby samples and changing Brush size. In the more complex wavy areas I made adjustments to density and just kept brushing over and over until I had a good enough meld into the surrounding areas.
That looks good and is the way I would have done it :)
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
spk8198
Post by spk8198 »
I tried the clone brush, but it looked really bad. I never adjusted the density though. Where is that found?
Kathy_9
Post by Kathy_9 »
It is on the Tool Options palette directly above your image. If you are not seeing it go to View -> Palettes and check Tool Options.
