When the image is scaled larger than the size of the viewing window ("workspace"?) the copy and paste does not work correctly. My X6 is the very latest version 16.1.0.48 installed from the latest download. The issue occurs on both 32 and 64 bit versions.
I am trying to simply select and copy a part of the image, and then try to paste that part back in to the image in another location, using CTRL-C and CTRL-E. Nothing fancy, only one layer, basic .jpg images.
The pasted selection does not display or move properly. When I try to drag it into place, parts of the selection disappear completely and other parts leave 'trails' across the image. This stays on the display until I re-zoom. Given that I do this a lot in the images that I work on, it is practically impossible for me to work with X6.
Fitting the entire image into the workspace window prevents the above issue, but given that I am trying to position with single-pixel accuracy on images often several thousand pixels square, that is not viable.
Is there likely to be a fix for this?
For what it is worth, I have updated my graphics card drivers and my Windows (7 x64 Ult) is fully up to date.
There is a second bug that I see frequently which is not a show stopper, but is still irritating.
If I use the clone tool to move small parts of an image to another area, when I then click on another tool (typically the selection tool) the part that I just cloned over reappears as I had done nothing to it. If I re-zoom, my changes are then shown so the clone tool is working, just a display bug.
I really hope these issues (especially the first) can be addressed. A
Rick.
