'DVD Folder is not supported'?
Mike S
Post by Mike S »
I have been trying to burn a .iso file (of a project that I have previously successfully burnt directly to disc) to disc using 'Copy to disc', in MF 3.0SE, but get the message 'This file format or DVD folder is not supported'.
Can anyone suggest what I might be doing wrong?
GeorgeW
Post by GeorgeW »
Do you have a "Burn disc image" function? I don't recall if MF3SE had that option, but in MF3 Disc Creator, there was an option to burn an image.
George
Mike S
Post by Mike S »
Ahhh!
Prompted by your comment, I have looked at this again and realise that I should be selecting the project's 'DVD video folder' as a source, rather than the 'Disc Image File', which was the default setting on the pop down menu.
It looks as though this will solve my problem. Thank you.
FYI, I can't find any 'Burn disc image' function, so believe you are right in thinking that MF3SE does not support the option to burn an 'image'.
If you will excuse my ignorance, could you possibly explain what the difference is between the 'disc image folder' and 'DVD video folder' and why you would want both?
Many thanks.
Mike S
Post by Mike S »
I have just found that there is a (untitled) 'Burn disc image' button at the bottom of the opening screen!
GeorgeW
Post by GeorgeW »
Mike S wrote:I have just found that there is a (untitled) 'Burn disc image' button at the bottom of the opening screen!
Yes, that's the one to burn the *.iso image file (which is like a package of what's going to be burned to disc) :)
George
