When I add a photo/clip into an overlay track, it is always too small and I end up having to re-size every one of the clips/photos.
Is there a way to define the size of the "default size" of an overlay clip/photo?
Overlay Track default size
Re: Overlay Track default size
you can set "Fit to screen" as the default for images in the overlay track - but not any of the other size options.
go to "Settings >> Preferences" (or press F6 when VideoStudio is open) - when the preferences dialogue window opens up at the top select the 'Edit' tab - then near the top click to check the box beside "Use fit-to-screen as default size in the overlay track" - click OK at the bottom and next additions to the overlay track should fit to screen.
You can also Copy and Paste Attributes.
Set the first image to the size you require, assuming its not full screen.
Right click the clip in the timeline Copy Attributes
Shift Click to select all images, right click to Paste attributes.
Images will all be the same size, unfortunately will be in the same position so you will have to re-position them, but you had to do that anyway.
Nigel
The copy and paste attributes works for me. This is much better.
Thank You.
Thank You.
