Copying and Pasting in X6
caspia1
ram: 16gb
Hard_Drive_Capacity: 1Terrabit
Monitor/Display Make & Model: twin hp displays
Corel programs: Pro 2023 Ultimate
Post by caspia1 »
Bought x6 a couple of weeks ago together with a new Windows 8.1 and 64 bit pc.
I get a problem when I paste part of one image into another one.
If I want to move it or enlarge/decrease the pasted part, it freezes or only part of it appears.
However, if I then click on the composed image and reduce the size a bit, the pasted part appears ok.
Nuisance as it slows the process down and should not be happening.
Any clues, please, as this never happened with X3 running on Windows 7 32 bit?
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Copying and Pasting in X6
Post by Kathy_9 »
I haven't experienced that issue with X6 in my work flow so I don't think it's an "across the board" issue with X6.
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
Some of us reported very slow refresh/redraw rates, I think because of SP1. There has been lots of discussion about SP1 breaking features. If you installed SP1 but have not installed the hotfix to fix the zooming problem, see http://forum.corel.com/EN/viewtopic.php ... &start=105 (near the bottom of page eight) for the hotfix. I think this solved my redraw problem.
Mark
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Hi Caspia,
Your profile still mentions that you are using XP Pro, yet your post at the start suggests that you have just upgraded to Windows 8 from Windows 7. Could you please update your profile so that we are sure which system you are using .
caspia1
ram: 16gb
Post by caspia1 »
hartpaul wrote:Hi Caspia,
Done. Thanks
hartpaul
ram: 8 Gb
Post by hartpaul »
Hope you had your problem solved Caspia1.
I am using X6 on a Windows XP Home machine and I made a selection from one image, Then Copied and pasted as a new layer on a second image. I was able to move the pasted part around without any delay. But then I did not install SP1 so have not experienced the zoom problems or the delays.
I repeated that procedure on a Win 7 laptop with both the 32 and 64 bit versions with the same results.
I currently have no need for SP1 as I still use X2 for main main work with photos and X4 for text capabilities so thats why I did not apply it. By the time I get around to using SP1, I am hoping all the problems will be fixed (prob about the time SP2 becomes available).
caspia1
ram: 16gb
Post by caspia1 »
hartpaul wrote:Hope you had your problem solved Caspia1.
Problem solved!
I checked if I had SP1 included in the purchase and it was. So I downloaded the patch as advised and it solved the problem completely.
Many thanks for all the great advice.
