Can I delete ImageDB.db file?
pstein
Corel programs: PSP X2
Post by pstein »
As I observed Paint Shop Pro X2 creates (under Win 7) in
C:\Users\P\AppData\Local\Corel\
a big file
ImageDB.db
I guess it contains meta information about previous edited pictures.
Can I prevent in PSP creation?
Can I simply delete it?
Will it be re-created on-demand?
Peter
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Can I delete ImageDB.db file?
Post by Kathy_9 »
Yes, you can delete it but it will be re-created when the program is next launched. Typically this is deleted if the user is having an issue with the program hanging.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
I don't know about X2, but imageDB in X4 is the Collections catalogue database for the manager/browser. You can delete it but you'll have to rebuild it if you want the manager functions. I don't know how long that would take, or if PSP also rebuilds the existing thumbnails at that time.
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Post by MarkZ »
I've deleted this file a number of times, for example to illustrate use of Collections. As you recreate the Collections it grows. Deleting it is one way of clearing up garbage and starting over.
Another area that uses lots of storage is Thumbs (C:\Users\MarkZ\AppData\Local\Corel PaintShop Pro\16.0\Thumbs). I'm not sure if thumbnails are deleted if they are not used for a long time but this directory can become very large. I doubt if the system cleans this up; just had a look and there are thumbs of images I have not accessed in many months.
Mark
edwinn
motherboard: Intel
processor: Intel Core i7 - 8 core
ram: 16 GB
Video Card: Intel
sound_card: Integrated
Hard_Drive_Capacity: 500GB 4TB
Monitor/Display Make & Model: Samsung 2494 - 1920x1080
Corel programs: PSP X4
Post by edwinn »
Thought I'd resurrect this thread (after searching the forum) because X4 seems like it's getting slow to respond, especially creating new folders or moving images in between folders.
So just a few mins ago, went to C:/Users/edwinn/AppData/Local/PSP/14.0/Thumbs
did a "properties" and found 10680 files, 5652 Folders, and 3.91 GB (4204 MB).
Wow.. I'd like to wipe as much of that away as possible and start the dB over, but without losing settings and paths, etc. Please advise what to delete, and what NOT to delete. This is to generally speed things up and reclaim drive space.
What about: /14.0/database/ImageDB.db file at 156 MB?
-Ed
MarkZ
ram: 8 GB
Post by MarkZ »
The ImageDB file can be deleted and it will be recreated the next time PSP is opened. If in doubt, after closing PSP rename the file to something else (in case you want to recover it later) and then restart PSP - you should see a new ImageDB file. You can then decide to delete the (old) renamed file.
I have deleted many Thumbs sub-directories without creating problems. I just did an experiment: renamed Thumbs directory and opened X8. It opened normally but was a bit slow as the thumbs for the active directory were re-created in a new Thumbs directory. Then closed PSP, deleted the new Thumbs, renamed the old back to what it had been and all worked well. So it should be safe to delete the Thumbs directory.
Mark
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
I believe that the Thumbs folder is created to speed up loading the thumbnail images that you browse when you open folders. So deleting it doesn't really hurt anything as long as you don't mind it taking a bit longer for the thumbs to be rendered again when you open a folder of images.
JoeB
Using PSP 2019 64bit
edwinn
motherboard: Intel
ram: 16 GB
Video Card: Intel
Post by edwinn »
MarkZ wrote:I have deleted many Thumbs sub-directories without creating problems. I just did an experiment: renamed Thumbs directory and opened X8. It opened normally but was a bit slow as the thumbs for the active directory were re-created in a new Thumbs directory. Then closed PSP, deleted the new Thumbs, renamed the old back to what it had been and all worked well. So it should be safe to delete the Thumbs directory.
Thanks, I did that this morning.. renamed the DB file and Thumbs folder in separate tests. But kept the DB file at ~150 MB and deleted the Thumbs folders. Actually decided to RaR the thumbs to an external USB drive. There were 21 RaR file, 184 MB each. :)
After that, notice I had an X5 (v15) Thumbs folder (never registered that trial) and deleting them, saved another 1GB.
-Ed
