Just got my PSP X6 installed and patched and updated and all...
Question 1) For those of us with 64-bit Windows, is the only reason to have the 32-bit version installed is if you wanna use the plugins?
Question 2) Is the KPT plugin the same for X5 and X6?
I did discover that the NIK plugin that was included with X5 works with X6 32-bit by simply copying the "NIK SOFTWARE" folder from the X5 plugins folder to the 32-bit X6 plugins folder. No such luck with getting it in the 64-bit version... So looks like it'll be a bunch of back-n-forth between versions if I wanna use the plugins. What really sucks is that you can't run both 32-bit and 64-bit at the same time. You at least CAN run both X5 and X6 at the same time.
EricB
X5 vs X6 with regards to KPT Plugin
SUTHNR
- motherboard: ASUS P6X58D
- processor: Intel i7 920 2.66ghz Quad Core
- ram: 6gb
- Video Card: MSI N250GTS TwinFrozr 1G OC GeForce GTS 250 1GB
- sound_card: on board
- Hard_Drive_Capacity: never enuf
- Monitor/Display Make & Model: Dell 3011 {angels...aaaahhhhhhh!!!!!!} haha!
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: X5 vs X6 with regards to KPT Plugin
Yes, you would use the 32-bit version to access any of your older plug-ins that are not made for 64-bit software. The KPT Collection is the same in X5 and X6.
Here's a thread you may want to read through regarding a script fix for Nik. http://forum.corel.com/EN/viewtopic.php?f=56&t=51492
pdxrjt
- processor: Intel Core i7 - 4.2 GHz
- ram: 32 GB
- Video Card: NVIDIA GeForce GTX 1080
- Hard_Drive_Capacity: 10TB Int.
- Monitor/Display Make & Model: Acer 32 inch x2
- Corel programs: Paint Shop Pro 2018
I have the latest version of X6 and many plus ins such as NIK and Topaz now work fine.
Adverts for Corel products when you close PSP don't bother me.
