Corel VideoStudio Pro X6 version difference ?
Can someone tell me what is the difference between the trial version and the purchased version of Corel VideoStudio Pro X6 ???
I downloaded VSX6_Pro_PF and VSX6_Pro_TBYB as one is a bigger bytes size file than the other ???
Thank You.
Thank You.
Re: Corel VideoStudio Pro X6 version difference ?
The trial version is a fully working version, and does essentially all that the purchased version can do. However, you get less by way of content (e.g. less menu templates and sample files) to keep the download size of the trial down.
Thanks for answer, why is it that the Pro X6 version takes longer to encode AVCHD Video (.MTS) movies to MP4 as the Pro X5 version used to take much less time ?
Thank You.
Thank You.
Sorry but I'll have to leave your last question to someone else since I don't usually re-encode AVCHD footage -- which is already mpeg-4 but made with the h.264 codec -- to another version of mp4. And I certainly have never made any comparison between the encoding speeds for such a conversion between X5 and X6...
canuck
amran wrote:Thanks for answer, why is it that the Pro X6 version takes longer to encode AVCHD Video (.MTS) movies to MP4 as the Pro X5 version used to take much less time ?
Thank You.
Do you have a short clip that you could upload to a free web sharing site such as 4Shared or Up4Down or some "cloud" server. We could the download it and do some test for comparison. That way we would be working with the identical clips.
Also how much is "much less time"? Are you using identical settings in X5 and X6?
Yes i use same settings, here is a sample for testing
http://nerobackitup.pogoplug.com/s/VAzietB7IbU/
Thank You.
Thank You.
Hi canuck
I ran a few tests yesterday using my own MTS files and indeed X5 is much faster than X6
12 minutes for X6 compared to 3.5 minutes for X5.
I have to retest and make sure I have the same settings for both versions including the hardware acceleration etc. and ensure Smart Render is working for both versions.
I have to say that I wouldn’t normally convert the MTS to MPG4, when I did MTS to MTS the render times were much alike, so maybe a difference in the MPEG4 templates, I suspect Smart Render???
Anyway I will run other tests using amran’s sample
Yes please update software as i convert large files and require saving time, my files are in the new AVCHD 2.0
Thank You.
Thank You.
Original properties of Ghousia Masjid Albion Road.MTS 710Mb
PAL (25 fps)
MPEG Transport-Stream Files
24 bits, 1920 x 1080, 25 fps
Frame-based
(HDMV-PAL), 16:9
H.264 Video
Video data rate: Variable (Max. 22000 kbps)
Audio data rate: 448 kbps
Dolby Digital Audio, 48 KHz, 3/2(L,C,R,SL,SR)
Convert using X5 Share Create Video File MPEG4 (11 minutes) 432Mb
NTSC non-drop frame (30 fps)
MPEG-4 Files
24 bits, 1920 x 1080, 30 fps
Frame-based
H.264 Main Profile Video: 15000 Kbps
32000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 128 Kbps
Convert using X6 standard template (10 minutes 10 seconds) 438Mb
Video Studio X6 has been improved to allow 25fps 1920 x 1080
PAL (25 fps)
MPEG-4 Files
Frame-based
H.264 High Profile Video: 15000 Kbps, 16:9
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 192 Kbps
Yesterday my tests showed a marked difference in the times to render my video, not sure why, maybe selected the wrong template? Today I used your files, making sure X5 and X6 were setup the same. The render times are pretty similar as shown above.
X5 does not allow for MPEG4 Pal standards so cannot render to Mpeg4 25fps however this has been addressed with the release of X6.
You are best using X6 to be able to retain your frame rate of 25 fps.
One question, why are you choosing mpeg4 as your final output file?
what are you using that file for?
PAL (25 fps)
Frame-based
(HDMV-PAL), 16:9
H.264 Video
MPEG-4 Files
Frame-based
PAL (25 fps)
MPEG-4 Files
Frame-based
Which is this standard template and how i select to use, i normally just out put through 'create video file' and select MPEG-4
i create the output files for uploading onto youtube to maintain best quality
Thank You.
Thank You.
By standard template I mean Share Create Video File—any option in the list other than the Custom option.
The default/standard templates may not use the correct properties for your renders,
In particular the frame rate may not use 25fps, (as when using X5.) the interlacing may use Upper Field when you may require Frame Based or Lower Field, these particular properties should reflect the ones used in your original video file, at least where possible.
You can also use Make Movie Templates Manager to create your own templates.
Using X6 creates a template pretty close to your original.
The default data rate is 15000kbps is used, I do not know if increasing this to 20000, (max setting for Mpeg4) will improve quality, it will certainly increase the file size.
By the way you did not say what the difference was in your render times, in the end I concluded there was little difference?
It was a good difference like 30 odd mins extra depending on file size, i manage to resolve the issue by installing the trial version insead of the one provided via purchased link
Thank You.
Thank You.
canuck
amran wrote:It was a good difference like 30 odd mins extra depending on file size, i manage to resolve the issue by installing the trial version insead of the one provided via purchased link
Thank You.
What version are you talking about?
Trial versions are the same as the purchased program.
canuck wrote:amran wrote:It was a good difference like 30 odd mins extra depending on file size, i manage to resolve the issue by installing the trial version insead of the one provided via purchased link
Thank You.
My first post to this thread and second post which is the answer gives the explanation to your question.
canuck
Well your posts are somewhat confusing since in your first post you are talking about comparing the trial and the retail X6 version and then in afurther post you are talking about rendering differences between X6 and X5.amran wrote:canuck wrote:amran wrote:It was a good difference like 30 odd mins extra depending on file size, i manage to resolve the issue by installing the trial version insead of the one provided via purchased link
Thank You.
