I'm trying to create a disc by creating dvd folders. However, the interface is telling me I need 8 gigs of required space, but it does not detect my "available" space and indicates it is 0. I have over 100 gigs of harddrive available.
The error message read, "unspecified error" Report ID0x8004041c
What should I do? What's going on?
Also, when I choose record to disc I get the same unavailable harddrive.
Create Disc Problem
THoff
I suspect that your UVS installation is damaged. Unless you have an ESD (Electronic Software Download) version of UVS, you can go to Control Panel -> Add/Remove Programs -> Ulead Videostudio -> Change/Remove, and then select Repair. Hopefully, that will fix it without having to do a complete re-install.
