I am not aware of having changed anything in settings or whatever, but I get an annoying clipping warning on jpegs, sometimes also in raws, with clipping warning TURNED OFF. Sometimes it disappears, when I use a plugin (zsoften for example), that means: I turn it on and off.
Does anyone have a solution?
It is on a windows 8 64 bit machine. Using it in linux (ubuntu 13.10), everything is fine!
see picture!
clipping warning always on, even on thumbnails, in jpegs
telegonos
Re: clipping warning always on, even on thumbnails, in jpegs
Nobody has a clue? Still haven't solved the problem.
Ubuntu, Aftershot Pro, Olympus Pen Mini 2
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Is that really a clipping warning? Or are you running into OpenCL issues?
If you have OpenCL turned on, try turning it off.
cheers
afx
cheers
afx
telegonos
THANK YOU! I mean, is it THAT easy...Your advice worked for me.
Is OpenCL kind of an experimental feature?
afx
- System_Drive: N/A
Well,
OpenCL depends on the quality of the drivers and most consumer cards have crappy drivers, that's why I bought a pro grade card for my main imaging box.
And the original development team was sacked during the integration of OpenCL, so I always have this nagging suspicion it was never fully finished.
cheers
afx
cheers
afx
I can confirm the issue and that it is OpenCL related.
It really looks like a kind of clipping warning, with two levels: cyan and dark blue. Perhaps some feature accidentally turned on while releasing...
|| Cezary Żemis <cezary.zemis@pronet.pl> | www.cezaryzemis.name
|| ph.:+49 176 7327 8527|skype:cezzem
