Hi !
I upgrade my system from 13.04 to 13.10 and the ia32-libs is not available anymore in Ubuntu.
As result, it is not possible to install AfterShot in the new Ubuntu, in both versions (32/64 bits).
I even tried to add the 13.04 multiverse repository to my system, to install the ia32-libs from there, but it FOOBAR the dependencies in my system so badly that I had to re-install it from a clean install.
Do you have any other options ? May be a beta version of a really true 64 bits (no 32 bits dependencies) ?
Or any other suggestions ?
I appreciate any comments !
AfterSHot on the new Ubuntu 13.10
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: AfterSHot on the new Ubuntu 13.10
13.10 should install the 32 bit DEB just fine, no need to muck about with a pseudo 64bit package anymore.
But... The 32bit deb downloaded might be a bit old or broken according to another thread...
cheers
afx
cheers
afx
marozsas
- System_Drive: B
- motherboard: Intel
- processor: i7-3770
- Video Card: Gallium 0.4 on NVC8
- sound_card: intel
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: AOC 23"
No, there is not a ia32-libs candidate to 13.10. Look:
If you google ("ia32 ubuntu 13.10") for this specfic issue you can find a lot of references to the removal and workarounds for specific programs. The generic one that messed up with my system is: http://ubuntuforums.org/showthread.php?t=2182653
Code: Select all
root@i7x:~# apt-get install ia32-libs
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package ia32-libs is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
lib32z1 lib32ncurses5 lib32bz2-1.0
E: Package 'ia32-libs' has no installation candidate
root@i7x:~#
install the 32 Bit version.
and after that, do
Code: Select all
sudo dpkg -i --force-architecture /path/to/the/32bit_ASP_Version.debCode: Select all
sudo apt-get -f install-
marozsas
- System_Drive: B
- sound_card: intel
SOLVED ! Re: AfterSHot on the new Ubuntu 13.10
Thank you shurito ! That did the trick !
best regards,
best regards,
