I have tons of raw photos taken with a t2i. One out of every 4 or 5 occasions, when clicking through the photos, the images turn white. Sometimes they stay that way, other times the problem clears up when the program restarts. If I go to export them, they are white as well. Occasionally, the program hangs. Interestingly, newer t4i raw files do not have this problem. Has anyone found a fix for this?
White Garbage Display on Photos
Trucks
- System_Drive: N/A
- motherboard: 64bit
- processor: quad
- ram: 3GB
- Video Card: Nvidia
- sound_card: onboard
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Eizo S2243 W
Re: White Garbage Display on Photos
- clean the cache
Regards
Trucks
- clean the cache
Regards
Trucks
Thanks for the reply and for confirming my suspicion. I did that this morning while waiting for an answer, thinking it to be the logical solution. I went into my ASP folder and removed only the folders that were affected. I restarted the program and it seems ok, but like I said, this problem can come and go so I'll report back if it keeps happening. One question though, when you mention clear the cache, is there a button to do that or just do it manually by nuking everything in the cache folder?
Trucks
- System_Drive: N/A
- processor: quad
- ram: 3GB
no, there is no such button, you have to do it manually. You don`t need to nuke everything in the Cache Folder, you can nuke the whole Folder. But it would be a great feature...
Regards
Trucks
Regards
Trucks
