Vectors seem to have a mind of their own. If I created a new vector from pen/line and wanted to add another line to that, same properties, sometimes it allowed adding the line and other times not. I could not figure out what the rules were. I'm aware that using the ctrl and shift keys does things such as adding nodes but, again, this seemed inconsistent. Selecting an existing vector would sometimes behave like a selection with the pick tool and other times the line with nodes only (what I wanted) would select. Fortunately I did figure out how to copy from one vector into another, although I was not successful with this:
I am using a Bamboo tablet and although it adds precision it was difficult to start a line and not have two nodes added, because of bounce? In other instances I would add a line, click on the check to complete it, then go to start another line and the new starting point would connect to the end of the previous, this with the continuous line unchecked. Happened numerous times. Ability to edit nodes saved the day numerous times.Cassel wrote:Maybe too simplistic, but did you dry dragging one such "path" from one vector "group" to the other?
With text, I found it hard to tell how to select existing text vs. starting new, but managed not to screw up on that. It is very hard to find just the right spot to click on to get at exisiting.
In one of the postings today there is mention of some actions such as cloning being arbitrary.
In my case I would make a change, zoom in, some portions of the vector would not be visible although the nodes were, make a change that does not appear and I learned that scrolling that portion out of the window and back would make the change appear. So I did lots of scrolling to see the results of my editing. Perhaps this is an SP1 issue. Overall, I've found vectors to be difficult to work with. I'll need to think about how I would make them better - keep notes the next time I get into graphic work.brucet wrote:No it's all random. Sometimes if I do a zoom in or zoom out the 'missing' edit appears!!!
eg. if I clone something out all is ok. Then if I go to the Pan tool the clone is missing. On zooming in or out the cloned edit re appears!
