Recently I'm having lots of problems to run X4 and X5 versions.
The most annoying is that both gave me the "Load from stream error".
I delete from the folder Roaming the foders corresponding to X4 and X5. When I restart the programmes work fine.
I start de programme again and when I want to delete the folders created within the programme (for example "Berlin" where i put files to work with) I get the error message again.
Any suggestions?
I have reinstalled botn versions again and I get the same problem.
Is it normal to have this error message?
Many thanks
Alfons
Video Studio X4 and X5
alfons
- processor: i7 9700
- ram: 32GB
- Video Card: Gforce GTX1650
- sound_card: Sound Blaster Audigy FX
- Hard_Drive_Capacity: 1TBSSD+4GB
- Monitor/Display Make & Model: HP 24Uh
- Corel programs: VS X4-X5-X8-X10-2018-2020-2022
Re: Video Studio X4 and X5
Of course it is not normal to have error messages.
See if this article on the Corel Knowledge base solves your problem :- http://tinyurl.com/Streamerror
alfons
- ram: 32GB
Still the same deleting all the listed files *.dat
I can see that the best is to rename the folder in Roaming/Ulead Systems/Corel..../14.0 and restart X4 or X5.
Loosing all the folders made within the programme.
Anyway many thanks Brian.
Alfons
Does this happen witn versions after X5?
I'm thinking to update to the latest version.
Bye for now.
Alfons
Bye for now.
alfons
- ram: 32GB
One last question?
Do any X4 or X5 put speech on any subtitle?
I read that X6 does something like it.
Do you understand my question?
Hi alfons
I think the problem is related to the library after deleting the folder Berlin.
If the files in that folder were added to the library, especially if you added VSP type files you may see this error.
Image and Video clips will request a re-link, but the VSP will be corrupt as files used in the VSP have been deleted.
Take care not to add VSP files to the library.
Note :-
From Settings - Library Manager you can reset the library
Note :-
