X6 Ultimate - cannot install ultimate features
xoechz
- motherboard: ASUS P8H77V-LE
- processor: Intel Core I7 3770
- Video Card: ATi HD 7750
- sound_card: M-Audio Delta 2496
- Hard_Drive_Capacity: 120GB
- Monitor/Display Make & Model: Acer X233H
Hello!
I have just bought PaintShop Pro X6 Ultimate. I have installed the 64bit version and now I try to install the Ultimate features (CreativeCollection and PerfectlyClear). But that does not work!
Every time I try it, the installation aborts because "the path is empty". No matter what I do, it´s always the same. Uninstalled PSP, installed again. Re-downloaded everything. All does not help!
I have also downloaded the CreativeContent from my member account, but there is exactly the same error. I cannot install any content for PSP. What can I do?
- hartpaul
- ram: 8 Gb
Re: X6 Ultimate - cannot install ultimate features
Install both versions of PSP, the 64 and 32 bit version. Many plug ins will not run with the 64 bit version so if you use a lot of plug ins then you may need the 32 bit version anyway. I have installed both versions followed by the creative content on my Win 7 64 bit desktop and Win 7 laptop along with the creative collections etc with no problems.
xoechz
Thanks for the answer.
I have tried that, re-installd PSP again, this time in 32 and 64 bit, but the result is the same. Same error and I still cannot install any of the Ultimate additions. What´s wrong here? I do not understand this. PSP is up to date, no updates available.
Any other suggestions?
xoechz
Still no luck!
Every time I get this "The given Path is empty" error message.
So, can I manually enter or correct this path somewhere? In the registry or in an .ini file?
I want to install these files now. I have paid for Ultimate and cannot use it. That´s a bit... unsatisfying.
xoechz
No ideas anyone? No one who had similar problems?
Cant be true that I cannot install what I have paid for.
Since you have only just bought the program, and Corel has a 90 day free support option for installation problems, I suggest you take it up directly with them since no one here seems to have experienced the same problem or have any workable suggestions... (And just to make clear, this is a user to user web board. Though we use the Corel servers, no one here is a Corel employee...)
To access this support, you must have registered your product with Corel. You then go to Corel.com and sign in. Then click on Contact Support. You will need then to get a Support Code, the instructions for which are:
Free Warranty Technical Support
If you have purchased or registered a supported product within the last 90 days, you are eligible for one-time free installation or activation support. If you require this service, you will need to use a support code to submit your question online. To obtain your support code, you will need to register your product if you have not already done so, and a support code will be sent to you via email. Once your question is submitted, consumers can expect a response within 6 business hours and businesses can expect a response within 1 business hour. If necessary, a technical expert will schedule a call-back to further assist you.
xoechz
Ok, sorry, I did not know that.Ken Berry wrote:..., no one here is a Corel employee...)
Since writing the above, I added a bit more by way of edit, so you should read that too...
- hartpaul
- ram: 8 Gb
Also if you get your problem solved, please come back here and write up the solution so others that come later may benefit.
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
Here is a link to someone posting about a similar problem. It appears they did not find a solution. http://forum.corel.com/EN/viewtopic.php?f=56&t=51667Ken Berry wrote:Since you have only just bought the program, and Corel has a 90 day free support option for installation problems, I suggest you take it up directly with them since no one here seems to have experienced the same problem or have any workable suggestions...
Mark
