I've just got round to installing SP1...
It still loads Nik plugins, where you can save as from the software once you have made any changes. But, if you OK the action, expecting it to return to PSP with the altered image, it still hangs PSP... 'not responding'. Not good enough Corel!
More importantly for me, and I'm sure others... If you load an image or images in 'Untabbed Documents' mode, ie each image is within its own window. This is VERY useful when working on multiple images so you can compare what you're doing between images... Now in PSP X6, when you zoom on a particular image only the image within the window frame zooms, and the window remains static. Which means as you work between images or want to place images on the screen, you have to manually drag the corners of the windows to resize them on the screen. Previous versions always zoomed the whole box. This is what made PSPs UI so intuitive, and very quick to use... now it's just clunky!
For this reason alone, I have to use X5. (let me know if there's a workaround or setting I'm not aware of)
Also still seeing artifacts around the work area (see attachment).
I was expecting better for SP1... disappointed!
Rgds,
Howard
