Thanks Michaelmichaelfwoern wrote:
I have found out, what the problem is and how to get a workaround:
It seems that the installer starts the 32 bit msi, even if you are running the 64 bit Version only.
To install the Service Pack just do the following:
1.) Start the installation an run it, until you get the license agreement dialogue. Do not click anything then.
2.) Go to your temporary files directory (on my computer it's "C:\Users\Michael\AppData\Local\Temp". There should be a "Corel PaintShop Pro X6" Directory there. Copy it to some other place, after that agree to the license agreement, start the Installation, get the error message and close it. Then the installer deletes the content of the temporary directory. For that reason you should copy it before.
3.) Go to your copied "Corel PaintShop Pro X6" Directory, then open the subdirectory "16.1\Setup". Delete "PSPPro.msi", Copy "PSPPro64.msi" and rename the copy to "PSPPro.msi". Then go to the "16.1" subdirectory and run "Setup.exe". After that it works!
This solution worked great for me
