Hey guys.
So I'm using Paint Shop Pro 8, and, for some reason, when I started it up today all my preferences had been reset. (All the tool options, and things of that such) It also had reset all my key bindings. How do I reset them? I tried going to Help>Keyboard Map, but that doesn't let me edit them. Any help? Thanks guys!
Paint Shop Pro Key Bindings Reset- How do I set them again?
Hopper200456
I draw and animate for my YouTube channel, that you should defiantly go check out!
Like Minecraft? Like 2D Animation? Like enjoyment? Then check out The World of Minecraft!
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Paint Shop Pro Key Bindings Reset- How do I set them aga
Well I don't have PSP 8 but View -> Customize will bring up the customization dialog in every other version I've ever owned.
THen under the Keyboard tab you will find options for changing key bindings.
If PSP 8 lets you save out your workspace as a file I would recommend doing that once you have it all setup the way you want it. Then to restore everything you just load in the workspace.
Again, in later versions this is found in File -> Workspace -> Save
Hopper200456
Thanks. I was able to reset all the bindings from there, thus making them all the default. (Which is what I use).
Also, I'll look into seeing if I can save my workspace.
Thanks!
Edit: I can save my workspace, and I did. Thanks for the heads up!
Thanks!
