CamStudio 2.7.2
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
CamStudio 2.7.2
Post by pepegota »
Camstudio's mp4 files are not accepted by Videostudio Pro X6 yet, they play well on other players.
Re: CamStudio 2.7.2
Can they be inserted in the VS timeline? If so, can you right click and give us the exact Properties? That will at least give us a clue as to which codecs -- video and audio -- were used to produce the files...
pepegota
ram: 64 GB
Re: CamStudio 2.7.2
Post by pepegota »
No, they cannot be inserted into the time line. Error message: Unable to open file. File format mismatch. How did they encode to mp4? No problem using VLC player. VS not flexible enough, i guess.
However, AVI works well.
Re: CamStudio 2.7.2
Do you have a program which will tell you the properties of the file, and particularly the codecs used on it?
canuck
operating_system: Windows 8.1
Re: CamStudio 2.7.2
Post by canuck »
pepegota wrote:No, they cannot be inserted into the time line. Error message: Unable to open file. File format mismatch. How did they encode to mp4? No problem using VLC player. VS not flexible enough, i guess.
Can you upload a short (10-20 secs) sample mp4 file to a free webhosting site for us to download? We can then try to duplicate what you are getting.
pepegota
ram: 64 GB
Re: CamStudio 2.7.2
Post by pepegota »
Mp4 extensions not allowed for upload. No audio in the video.
mp4_Data.txt
(2.28 KiB) Downloaded 167 times
pepegota
ram: 64 GB
Re: CamStudio 2.7.2
Post by pepegota »
A recode of the mp4 file is attached. It played well.
mp4_recode.txt
(1.73 KiB) Downloaded 272 times
pepegota
ram: 64 GB
Re: CamStudio 2.7.2
Post by pepegota »
Recorded to m2ts and plays fine. Data attached. Camstudio has a problem or Corel?
MP4_M2TS.txt
(2.2 KiB) Downloaded 200 times
pepegota
ram: 64 GB
Re: CamStudio 2.7.2
Post by pepegota »
FYI:
Changed codec from Cinepak to ffdshow and now it works fine.
dbz2000
processor: InTel[R] Core [TM] i9 7900X 3.60 Ghz
ram: 16 GB
Video Card: GTX 1070
sound_card: NVIDIA High Definition Audio Device
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Dell ST 2310 Analog
Corel programs: VideoStudio 2018_ VideoStudio Paintshop
Re: CamStudio 2.7.2
Post by dbz2000 »
Would like to know how does one change codecs from one pack to another? :?: Is there a program for that or can it be done in VideoStudio? :?: Just wondering in the event I have a similar issue in the future.
Thanks in Advance;
DBZ2000ny
"Instead of trying to add years to your life; try adding life to your years"
pepegota
ram: 64 GB
Re: CamStudio 2.7.2
Post by pepegota »
1. Open Camstudio and select options.
2. Under options select "Video Options."
3. Under compressor change the codec.
A better codec for mp4 is Intel lYUV Codec
