Copy sets
Bugs & Suggestions
sebastiaankop
operating_system: Linux
motherboard: motherborad
processor: pentium
ram: 2gb
Video Card: Dontknow
sound_card: Dontknow
Hard_Drive_Capacity: 100000
Monitor/Display Make & Model: Neovo
Copy sets
Post by sebastiaankop »
Hi all,
I use AfterShot 1.2.0.7 on Ubuntu 12.04 (with all the updates installed).
I open file > preferences > copy sets. Editing a existing set i notice none of the checks are 'on'. So it is really just a empty set.
Making my own set I noticed that AfterShot forgets what I have checked (the information that needs to be copied).
I need a little help with this please.
Thanks.
Sebastiaan.
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Copy sets
Post by afx »
You misunderstand how this works.
You need to select what to copy, not the state. Otherwise a copy set would not be able to switch off a setting.
cheers
afx
sebastiaankop
processor: pentium
ram: 2gb
Re: Copy sets
Hi afx,
Ok. I understand.
I make a new profile and name it copyright.
Then I edit the profile copyright.
I tick on some of the settings that I want in this profile to 'on'.
I save the profile.
When I reopen the profile all the settings that I marked are not marked.
What can I do better?
Sebastiaan.
afx
System_Drive: N/A
Re: Copy sets
Post by afx »
Bug ;-(
Test your copy set, it should work.
Just tried it here and the settings are not displayed when re-opening a copy set.
But the copy set works.
cheers
afx
sebastiaankop
processor: pentium
ram: 2gb
Re: Copy sets
Must i do something so corel can fix this bug?
afx
System_Drive: N/A
Re: Copy sets
Post by afx »
You can tell the Monkey (see my signature).
cheers
afx
