squaring up image edges
DrZaat
motherboard: MSI Base Board
processor: AMD FX[tm]-6100 Six-Core Processor 3.30GHz
ram: 16 GB
Video Card: NVIDIA GeForce GT 610
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Acer AL2216W
Post by DrZaat »
Paint Shop Pro X5
I have some photos of old magazine covers, some of which weren't taken straight on, so that the covers aren't square. With previous versions of Paint Shop Pro, I could drag a corner out until it made the image look square [actually, rectangular], but I can't figure out how to do it with this version.
Anyone have any idea how to square up the edges of an image?
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: squaring up image edges
Post by Forriner »
Are you talking about straightening an image, or correcting perspective?
Both the Straighten and Perspective tools are under one button on the Tools toolbar. Click on the little triangle to the right of the icon.
Or try the Pick tool (arrow, keyboard shortcut = K) that shares a button with the Move tool. Use the Ctrl or Shift key while dragging a corner to change perspective.
DrZaat
ram: 16 GB
Post by DrZaat »
Here's an example. I want to pull the upper left corner in this image until the left edge is straight up and down.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
I was able to do this using the pick tool in free mode.
DrZaat
ram: 16 GB
Post by DrZaat »
Yes, that's exactly what I want to do. I'll have to give it a try. I wasn't getting anywhere with the pick tool.
Thanks a lot! I hope I can make it work.
DrZaat
ram: 16 GB
Post by DrZaat »
Yes, it worked. It's a bit trickier than it was with the earlier version I had, because the image moved as you dragged it, so you could see exactly where you wanted it to be. With version X5, you have to guess if it's right and release the pick tool and hope it's the way you want it. But, at least I can do it.
Thanks again!
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
The Perspective Correction Tool works well with this.
Zoom in on the image as big as you can so you can see where the nodes go.
Drag the nodes to line up with the corners of the existing image, see attached:
Joëlle
Joëlle
(PSPX9 )
DrZaat
ram: 16 GB
Post by DrZaat »
Thanks. That worked too. I tried the pick tool and the perspective tool before, and I couldn't get them to do what I wanted. Hopefully, when I run into this again, I'll remember what to do.
