Shortcut to toggle all applied Filters
ariel
operating_system: Linux
System_Drive: N/A
Post by ariel »
Browsed ASP manual, googled around - found no answer.
Is there a keybard shortcut to toggle the applied "Filters" on and off?
In addition, a one-click solution would be nice (couldn't figure that out either)
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Shortcut to toggle all applied Filters
Post by afx »
Unfortunately no.
cheers
afx
ariel
System_Drive: N/A
Post by ariel »
afx wrote:Unfortunately no.
cheers
afx
I will ask for this in the "feature request for the next version" thread then
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Post by Dutchmm »
Ariel
There is a keyboard solution that will take you back to the beginning of your workflow. Settings, Apply Initial Settings will take you back to whatever filters you apply to all images (as defaults, either to ALL raws, or just to all raws from THIS camera). It will also undo any flags you have set. It is assigned to [Ctrl] [Shift] + R by default. But be aware that unless your next command is Undo Apply Initial Settings - that is [Ctrl] + Z, all your hours of creative work will be lost :(
HTH
Mike
spoilerhead
System_Drive: N/A
Hard_Drive_Capacity: 13.5TB
Post by spoilerhead »
a non destructive solution is
[Ins] create a new version and switches to it
[Ctrl+R] Resets the version to defaults. And when you're done comparing
[Del] Deletes the version again and you're back to your original version.
my ASP Plugins - donation button ( send beer! :) )
linux,7d, glass and a huge mug of coffee.
If you got any immediate problems with my plugins, don't by shy on contact me on GoogleTalk.
afx
System_Drive: N/A
Post by afx »
Filter != applied settings...
The OP was asking for the filter....
cheers
afx
Dutchmm
System_Drive: N/A
Post by Dutchmm »
Fair enough, but then (now I understand what Ariel was asking about) what is the Filter Panel and its shortcut about? I don't seem to be able to make anything happen with it. Your book doesn't seem to mention it. Nor can I find the term in the AS help file. :?
afx
System_Drive: N/A
Post by afx »
Search for filter in ASG..
It is mentioned.
Or press the funnel shaped icon in the top icon row. It is fairly obvious.
cheers
afx
Dutchmm
System_Drive: N/A
Post by Dutchmm »
I looked at all the instances of Filter that the Document Viewer could find using its search function.
I also searched - in vain - for the expression "Filter Panel".
I know how to use the filter function. I even use it as part of my workflow. I even know how to bring up and dismiss the Filter dialog using my mouse.
What I don't know is what the shortcut "Filter Panel" does. If it still has some action attached to it, I cannot see what that action is. I thought it might be the action Ariel was after. Who knows?
afx
System_Drive: N/A
Post by afx »
Filter panel just toggles the display of the filter if I remember correctly.
cheers
afx
