cannot copy file
redrobot
ram: 512
cannot copy file
Post by redrobot »
hello
have been using PSP8 for a long time with no problems. i regularly copy files from my HD to a memory card but recently i have been getting the following error message for no apparent reason:
cannot copy [filename]: the directory or file cannot be created
if i try to copy a batch of files this does not happen for all files - just more recent ones. so half the files get copied, the others don't. i have checked file properties old files vs new and cannot see any difference. my memory card is not full.
any advice appreciated.
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: cannot copy file
Post by trueblue »
It sounds more like you have a glitch in the programme.
Have your tried restoring to default and trying again?
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
redrobot
ram: 512
Post by redrobot »
thanks for the reply. how would i do that?
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
Are you using PSP8 to copy files from one drive to another? I ask because it sounds more like the warnings I used to get long ago with FAT8 or FAT16 formatted disks. You could store a maximum of 512 files in the root directory, fewer if you used long file names (longer than 8.3 name.extent).
If you insert your card into your computer, open the Windows Explorer and right click on the drive to open Properties. Near the top of the first tab you should see Type of disk, and File system. If it's Fat or Fat16 I think that's the problem. You can do one of two things:
1) format as Fat32 to get more entries in the root. I'm not sure if "low" capacity media can be formatted FAT32, so a better option might be
2) create a sub-directory/folder and store the files in there. Subdirectories aren't limited to 512 8.3 files.
Of course I could be wrong. In that case disregard all the above.
Good luck.
redrobot
ram: 512
Post by redrobot »
tahnks for the advice. subfolder worked.
