Playback issues
canuck
operating_system: Windows 8.1
Re: Playback issues
Post by canuck »
lata wrote:Hi Canuck
I have sent the sample to your e-mail address
Thanks Trevor (and babdi)
Will play around with the file using X6 as well as Roxio Creator
babdi
motherboard: ASRock Extreme 11
processor: Intel 3770K
ram: 32 GB DDR3
Video Card: Asus 660TI 2 GB
sound_card: On board Realtek
Hard_Drive_Capacity: 6.128 TB
Monitor/Display Make & Model: 22",BenQ 2222 LCD HD 1920x1080
Corel programs: Video studio
Re: Playback issues
Post by babdi »
Thanks Lata and Canuck. Your efforts highly appreciated ! 8)
There is a light within a light and a shadow within a shadow. - Rembrandt
Re: Playback issues
Can someone please send me the video too? I'm now on the mend, if slowly, but getting back into things...
canuck
Re: Playback issues
Post by canuck »
lata wrote:Hi Babdi
The only difference in the two files seems to be the extension used, all properties appear identical.
The original uses “m2ts”, whilst the converted file uses “m2t”
Did you try re-naming the M2T to use M2TS.
Maybe your device only recognises m2ts types???
I used VX X6 to render the original m2ts file to a mt2 file using the "same as first clip" option. The attached image shows that the properties have some differences.
The mts2 and mt2 file would not play on any of my TVs (a Sony HD and a Samsung HD) via a USB stick. Both files do play via USB plugged into my WD Streaming Video device.
babdi
ram: 32 GB DDR3
Re: Playback issues
Post by babdi »
Canuck
That's a good finding. Why does X6 render with different parameters when we select "Same as first clip". Is that a bug
Ken
I have sent you the clip
Re: Playback issues
canuck wrote:The mts2 and mt2 file would not play on any of my TVs (a Sony HD and a Samsung HD) via a USB stick. Both files do play via USB plugged into my WD Streaming Video device.
Are the Sony and Samsung Bluray or simply HD devices?
When you say do not play are the files recognised or just do not show?
Did you try renaming the MTS types to use MPG as the files extension, do they now play via your USB
babdi
ram: 32 GB DDR3
Re: Playback issues
Post by babdi »
Lata
The files do play if rendered as MPEG-2 or MP4 as posted earlier. The problem is only with H.264
Re: Playback issues
Hi babdi
I was interested if Canuck had the same issues in playing the re-named files.
I realise that you have an issue in playing some formats.
By the way I did send via e-mail a MPG file, can you confirm whether you are able to play that file?
If you were to render to AVCHD using Mpeg compression the new file would use MTS as its extension, are you able to play that? Use Make Movie Templates Manager to create your template.
babdi
ram: 32 GB DDR3
Re: Playback issues
Post by babdi »
Lata
Your mpg file did not play
Re: Playback issues
Ok thanks, I will try another combination?
