Settings in VideoStudio
xinnjstar
motherboard: Gigabyte EP45-U3R
processor: Intel Core 2 Quad Q6600
Video Card: AMD Radeon HD6700 Series
sound_card: Onboard Sound Realtec
Hard_Drive_Capacity: 3T bytes
Monitor/Display Make & Model: Samsung 931B
Post by xinnjstar »
how to create your own setting in the video save options mpeg user setting. I can't find GG_App.ini file in X6.
The highest is 720X576.
Re: Settings in VideoStudio
Post by BrianCee »
so what sizes are you wishing to create ?
Hi xinnjstar
You can create your own templates using Settings - Make Movie Templates Manager.
They will then be available from Share Create Video File – at the bottom of the list.
But as Brian says it depends on what you wish to create.
The image you show looks like the standard DVD properties and are limited to 720 x 576 as those sizes are standard for a Pal DVD
xinnjstar
Post by xinnjstar »
lata wrote:Hi xinnjstar
Thanks for pointing out this to me. Thank you very much.
I would like to create to like 1200X800 or 1280X768 .
I have found out that only Mpeg-4 can do that. Mpeg the best is only at 720X576.
Post by BrianCee »
If you select mpeg-4 from the choice of available outputs then the default gives sizes near to what you require (see below) - then as Trevor has already said you can set up your own templates using either the custom button on that list or the make movie template manager
