I'm fairly new to Videostudio and loving it so far. I have two simple issues that I assume must be easily fixed, but darned if I can figure it out.
1. When saving video files, I usually prefer to customize the file settings. Is there a way to save my custom profiles? It's a bit tedious to have to manually reconfigure the settings every time I save a video.
2. Is there a way to enlarge or maximize the multi-trim editing screen? The editing I do requires attention to small details and the default size of this screen is simply much too small.
Thanks for your help.
Pro X6 - Two questions regarding customizing and multi-trim
flea099
- motherboard: Gigabyte PA55-UD3R
- processor: i5 750
- Video Card: Radeon 5850
- sound_card: Audigy 2
- Monitor/Display Make & Model: Acer AL2223WD
- Corel programs: Videostudio X8
Re: Pro X6 - Two questions regarding customizing and multi-t
I never use the multi-trim function, so can't help there, but I am sure someone will soon jump in on that.
On the saving of your favourities properties for a video, go to Settings > Make Movie Template Manager, and create a new Custom Template there with the format and Properties you want. You save it with a name you will recognise, then next time you want that format, go to Share > Create Video File, and in the drop-down menu, choose your new Template.
flea099
- processor: i5 750
Aha! Thanks so much, Ken. Exactly what I was looking for.
Hiflea099
Multi Trim
Unfortunately like Ken I do not use that option but prefer to use the scissors in the timeline.
Cut the clips into sections and delete the unwanted portions.
The square brackets adjacent to the scissors (mark-in F3 -- Mark Out F4) will also remove frame from the ends up to the curser position, make sure you are in Clip mode. Otherwise you will set the project playback range? The orange line.
http://lata.me.uk/corel/bluebar/blue_bar.htm (must update this page its now a white bar?)
Multi Trim, I right click the top header bar and found Maximise options. It does fill the screen but more of the preview screen than the timeline, anyway have a look.
Multi Trim
flea099
- processor: i5 750
Wow, it looks like all of my problems have been solved and then some. Thanks, guys.
