usb catalog
gordianus
operating_system: Linux
usb catalog
Post by gordianus »
I heb installed ASP on a portable pc and set the catalag to an external usb-disk. This works fine.
Followed tha manual to set the catalog portable, but that does not work. ASP crashes on a fixed win7 pc, as wel as on a Kubuntu pc when adressing the pictures with xmp.
Also says he can noet write to the xmp files.
Hope sombody can help me, because I love ASP, but need the Portability
Greetz,
Geert
Dutchmm
System_Drive: N/A
motherboard: Asus 97
processor: Intel i7 4785T
Video Card: Onboard Intel
sound_card: Intel AC97
Hard_Drive_Capacity: 2.5TB
Monitor/Display Make & Model: Philips 28"
Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: usb catalog
Post by Dutchmm »
Geert
Jeff heeft een webinar precies hierover gedaan. Dat wordt ergens op YouTube te vinden. Misschien is dat (in de engels) hier.
mvg
Mike
gordianus
Re: usb catalog
Post by gordianus »
I tried to change as seen in the webinar, but still the same problem on win7 and linux
Path to catalog on linux pc is media/GOR_500/Foto/Catalog
Path to foto's on linux is media/GOR_500/Foto/2013 But I always get the question marks to see
Sreenshots are attached
Dutchmm
System_Drive: N/A
Re: usb catalog
Post by Dutchmm »
I can't reproduce this ... partly becauseI don't have a Windows system of any colour to practice with. When I create the mobile catalog, the "contact prints" don't show the question mark I see in your screenshots. And the only kind of filesharing I have ATM is via Dropbox which makes a separate physical copy for each machine I share a directory to.
Does the question mark show up only on the second machine, or on both?
gordianus
Re: usb catalog
Post by gordianus »
The questionmark only shows on the second and third machine (1 linux & 1 win7), on the first machine everything works fine
Can I remove All those links, so I could give it a try to start all over again?
gordianus
Re: usb catalog
Post by gordianus »
I did everything all over again: making the catalog, making the links to the catalog on the diferent computers ans now it works!!
Thanks for the help
Dutchmm
System_Drive: N/A
Re: usb catalog
Post by Dutchmm »
Good to hear - Could you try to mark the thread as "solved"? I had a go, but perhaps only the OP can change the title
