problem regarding HDP
hellside
Post by hellside »
I am using PSPX6
for example, there is a BMP which is 2.25mb
if I use "save it as a new file", and chose lossless HDP, then I get a file 537k
if I use "batch action" and save this file as lossless HDP, then I get a file 1.2mb
Please check why this happens. Thanks.
canuck
operating_system: Windows 8.1
Re: problem regarding HDP
Post by canuck »
Please list step-by-step what you are doing so that we can duplicate what you are doing.
hellside
Post by hellside »
save as
save as
batch
batch
result
result
Please see the attachment.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Hellside, have you tried setting them both to lossy with a compression of 10?
Maybe PSP isn't saving them lossless.
canuck
Post by canuck »
hellside wrote:I am using PSPX6
I cannot duplicate your findings using PSP X6
"lossless" setting
"lossless" setting
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
I took a jpg saved it as a bmp file. Then went to X4 and did a Save as lossless and batch save lossless. Repeated with X6 . Results show no difference in either version.
hellside
Post by hellside »
after countless try, I think I find the cause.
the lossless is not really lossless, it is affected by the grey out option!
transfering a bmp 2.25mb using the two lossless set
I get one file 1151k and the other.....18k(of course it looks totally lossy)
please try this method
curious though, the output of lossy1 is 1365k and lossy99 is 19k, both larger than their corresponding "lossless" version
but lossy10 result is smaller than its corresponding "lossless" version
canuck
Post by canuck »
Yes, it seems that the setting of the compression factor is also applied to the "lossless" method. So it doesn't matter if you use the lossless or lossy method, the important parameter is the compression factor setting.
hellside
Post by hellside »
canuck wrote:Yes, it seems that the setting of the compression factor is also applied to the "lossless" method. So it doesn't matter if you use the lossless or lossy method, the important parameter is the compression factor setting.
is there a way to get a lossless HDP? since the lossy setting can't be 0.
and I also notice the transparency is not kept in HDP, though HDP support transparency.
hellside
Post by hellside »
I downloaded a plugin so photoshop support HDP
the real lossless HDP is in fact not much smaller than PNG...a 2.25mb BMP can be trans into a 1.30mb HDP
