Been using VidoeStudio Pro X5 for couple years and just picked up a used PC. It had XP and could capture with installed VS X5 with no issues. Today i upgraded to Windows 7, reinstalled VS X5 and cant get past the "Unable to switch Capture" error. I can capture using my Canon Vixia HV40 and Sony FX1000 via Firewire with no problems using HDV Split, Roxio Creator and Cyberlink Powerdirector, so problem must be somewhere with VS X5.I can "control" the camera (stop, play, rewind,etc) through VS X5, but the Capture and Option buttons are grayed out and no image in preview window.
Anyone have any suggestions?
I have tried googling and downloaded a few codecs and drivers but no joy. Naturally I have rebooted and tried fresh install as well.
Thanks all,
Darryn
Unable to switch capture error
Re: Unable to switch capture error
This is a problem many users have found when upgrading to Win 7 - the solution is to roll the firewire driver back to a 'legacy' driver.
There is an article here which will guide you through the relatively simple procedure :- http://tinyurl.com/legacy-drive
if you do not like that article do a Google search for 'Firewire legacy' and you will receive a few thousand options.
sealilly
- Corel programs: VideostudioPro Ultimate 2021
Thanks Brian, tried that last night with still no luck. I now have the Legacy driver selected and a reboot, still same problem
OK - well the only other suggestion I can offer at the moment is to do your capture in one of the products you have which do capture and then simply import to Videostudio for final editing and DVD creation.
