Chapters
redcar56
- motherboard: HP inbiult
- processor: Intel 7i
- ram: 8gb
- Video Card: Nav 1gb
- Hard_Drive_Capacity: 1tb
- Monitor/Display Make & Model: HP Pavillion 23xi
Chapters
Hi. I am operating Videostudio ProX5 and this is my first attempt.
I have transferred my film, edited, added music, added chapters with the little green marker, but when I create disc and try to use the chapter menus it finds them but will not create chapters, please help
Martin
Martin
Re: Chapters
Sorry martin - can you explain a little further - "try to use the chapter menus it finds them but will not create chapters"
did you not say you created the chapters in the timeline - so what exactly do you see in the Create disc module.
redcar56
- ram: 8gb
Re: Chapters
The film is filmed on a motorbike camera so has film is broken up into lots of segments and transferred to pc.
I do ,share,created disc,DVD,add/edit chapter,return,screen shows six chapters which is correct,return, shows one, next menu preview,but only shows one chapter. Film is long at 1hr50min but my old pinnacle studio made at that size just compressed more.
Totally lost
Totally lost
Re: Chapters
Hi Martin
When you return to the preview screen, the one showing the Gallery Tab and Edit tab.
Right hand side , What you see is the Main Menu aka Title menu
Immediately below the preview screen are the words, Display Current menu, (something like that) the drop down box will allow you to select and view the chapter menu.
And of course edit them.
redcar56
- ram: 8gb
Re: Chapters
Hi Trevor
There is no display current menu on my program display.
lata wrote:Hi Martin
Re: Chapters
what do you see in the area I have circled in red in the image below.
redcar56
- ram: 8gb
Re: Chapters
Main menu and if I drop down Europe trip 2013 which is the film title, no further chapters
redcar56
- ram: 8gb
Re: Chapters
This is the screen showing six chapters, I press ok and only one shows
Re: Chapters
Have you chosen a menu template which has the capability of 6 chapters - not all can - which menu template are you using for the chapter menu.
redcar56
- ram: 8gb
Re: Chapters
I thought the menu was chosen in the next step, I'm going to read the manual which I would think will be useless.BrianCee wrote:Have you chosen a menu template which has the capability of 6 chapters - not all can - which menu template are you using for the chapter menu.
I thought Pinnacle Studio was difficult at first but this program seems very hard to master. At least the chapter creation in Pinnacle was straight forward
Re: Chapters
If you are in the Create disc module that is where you create the menu - I prefer to add chapters in there as well - I do not usually do it in the timeline.
Unless you choose a menu template fairly early on in the create disc module you cannot see how your main screen and chapters are going to work out.
redcar56
- ram: 8gb
Re: Chapters
I watched that, my film is made up of about 147 clips so I can't use auto chapter because max is 99, I thought placing the green pointer on my edit was the chapter marks, I will try again tomorrowBrianCee wrote:Watch this Corel video - see if it helps you :-
http://www.youtube.com/watch?v=T0OOXdIr7WM
Re: Chapters
How many do you see in the drop-down list?redcar56 wrote:Main menu and if I drop down Europe trip 2013 which is the film title, no further chapters
If you have created chapters then there will be two or more options when you drop down.
The top option being the Title Menu
Choosing the second option will open /view the Chapter menu.
Then choose a template from the Gallery, I would suggest using a Thumbnail type.
Edit Tab
Now choose Customise-change Frame to Layout and select the amount of chapters, max 8 thumbnails per menu.
Post edited
The green triangles added to the timeline will show as chapter points. However in the past there has been issues using the timelines, so we would normally recommend adding chapters to the burner module, but now should work from the timelines.
redcar56
- ram: 8gb
Re: Chapters
Only one, the film saved name, no others that what's confusing melata wrote:How many do you see in the drop-down list?redcar56 wrote:Main menu and if I drop down Europe trip 2013 which is the film title, no further chapters
Edit Tab
