File format mismatch
dealoox
- System_Drive: B
Re: File format mismatch
My friend,
I don't understand what is my next problem and how can I fix it..
And always, every clip that I make I have to chםose 4.3?
Won't it change, right?
thanks!
thanks!
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
For this project you need to choose 4.3, for future projects you need to choose whichever size your video on the timeline is.
There is nothing you can do about your next problem. I was highlighting it now, so you were prepared for how it looks on a big screen.
dealoox
- System_Drive: B
My friend,
Or You don't understand me or I don't understand you, I don't know.
I start from the begin maybe you will understand me better.
I make a clip for my friend birthday.
Always I did dv (4:3 ) when I saved the project.
What is the differenece between dv and dvd?
Now you say dvd is the best saving format, So I believe you and do it.
But For example If I don't have any video in the clip?
I have differnt sizes of videos in the clip.
So what can I choose?
I have 352X288 size and 728X408 size and more different size videos.
And If I save the project in videostudio pro x6 What will I need to choose?
Please help me I have to finish the clip a.s.a.p
dealoox
- System_Drive: B
Someone can answer me please?
thanks!
thanks!
JUST DO THIS - Nothing else
Do not look at any other settings - do not change any other settings.
Put all your video in the timeline
Click on the "Share" tab at the top
Choose "Create a Video file"
from the pop up choose DVD/VCD/SVCD/MPEG - then choose DVD (4:3)
in the new window choose at the top where to save to on your computer
at the bottom give the video a name - Click on 'Save'
Video file will be created - - - Use it - - - - - THE END
dealoox
- System_Drive: B
Every project that I make I need to choose dvd (4:3)?
thanks!
thanks!
You only choose 4:3 if your video is 4:3
do not use it for EVERY project unless every project uses 4:3 video
if your project has 16:9 Video you will choose DVD (16:9)
You are using VideoStudio 11 - DO NOT USE A NEW VERSION NOW - make your video - talk another day about using X6
dealoox
- System_Drive: B
Ok my friend,
But I really don't understand still how can I choose between 16.9 and 4.3..........
I have a lot of videos in the clip.
Some of theme 16.9 video and the others 4.3 So what can I choose???
you didn't say you had 16:9 before
I asked for the properties of the file - you showed 4:3
If you have some 16:9 then choose 16:9
YOUR CHOICE - you choose - if you do not like choose different
dealoox
- System_Drive: B
My friend,
I don't want to choose 16:9 I just ask when I know what to choose?
I explained you that in my clip there are a lot of video sizes.
There are 16:9 size and 4:3 size.
So what better if I have 2 kind of sizes, 16.9 or 4.3?
Undesrstand me my friend?
BrianCee wrote:you didn't say you had 16:9 before
dealoox
- System_Drive: B
So what better to shoose if I have 2 kind of sizes, dvd 16.9 or dvd 4.3?
skier-hughes
- Microsoft MVP
- ram: 4GB
dealoox
- System_Drive: B
Each one says something different.
You say 16.9 and brian say 4.3
dealoox
- System_Drive: B
Ok....
I will choose 4:3 always, I hope it will be ok.
Thank you very much on your services.
You are very help me.
best reagrds.
best reagrds.
