File format mismatch
dealoox
System_Drive: B
Post by dealoox »
Hello,
Please help me.
I have problem when I import video.
It's says unable to open file, file format mismatch.
I have make a clip for wednesday!!
please who can help me??
In addition, LAST TIME WHEN I pressed "create video file" it stopped in the middle of the saving.
Why did it happen? How can I fix it?
thank you very much!
Best reagrds for all!!!
Re: File format mismatch
Post by BrianCee »
Hello
the first thing we need to know is what made the original video - what sort of camera - make and type please.
how did the video get from your camera to your computer - what method did you use
what extension does the video file have - what comes after the dot in the file name
dealoox
System_Drive: B
Post by dealoox »
Hello my friend,
I fix the problem with the format I just converted it to "mp4" format.
But I'm afariad about that it will stop saving again the project.
How can I fx it my friend?
Post by BrianCee »
OK it is good that you have fixed your first problem
but we do not know if it will stop again during rendering - you must try it and see - if it does then please make a note of any error message and let us know what it says.
You cannot damage your original video if it stops - that is safe - so please try to finish your video and see what happens.
dealoox
System_Drive: B
Post by dealoox »
Ok I will try to finish that a.s.a.p and reply you my friend.
dealoox
System_Drive: B
Post by dealoox »
My friend,
In addition when I save the project as video which format you recommend to me for saving the clip?
best reagrds!
Post by BrianCee »
That depends on what you are going to do with the final video - are you going to put it on Youtube - or watch it only on your computer - or burn a DVD to watch in a standard DVD player - or what ?
dealoox
System_Drive: B
Post by dealoox »
For a standard DVD, you must use DVD-compatible mpeg-2. So in Video Studio you choose either Share > Create Video File > DVD or else Share > Create Disc > DVD.
dealoox
System_Drive: B
Post by dealoox »
My friend,
I want save the project as video and after it I burn dcd with other program.
Post by BrianCee »
so - do what Ken suggests and make an mpg file by selecting DVD from the video types
why do you want to use another programme to burn the DVD - VideoStudio does a very good job of that
dealoox
System_Drive: B
Post by dealoox »
I don't know in movie maker there are a lot of effects that I do if I burn with it..
dealoox
System_Drive: B
Post by dealoox »
In addition,
can you explain me exactly what Will I press when I want save the project as video?
thanks!
dealoox
System_Drive: B
Post by dealoox »
I also want to save with videostudio as video and not burn because I want one copy of the clip that is saved on my computer?
understand me my friend?
Post by BrianCee »
To Create a Video - Click on the "Share" tab at the top of the screen.
a new panel will open - choose "Create Video File" then 'DVD' and continue from there - this will make a video to view on your computer AND that you can burn to disc
