Perfect Resize Photoshop plugin in X6?
Brad Waite
Post by Brad Waite »
Hi all,
I've been a long time PaintShop Pro user, but rarely use plugins. I believe I've used some Photoshop plugins on an earlier version, but I can't get onOne's Perfect Resize to work. Here's the instructions for their PS plugin:
http://www.ononesoftware.com/support/us ... toshop.htm
What's the analogy to those instructions in PSP? "Batch Process" seems the most likely candidate for "Automate", but there's no Perfect Resize options there.
I understand that X6 will load 8LI plugins, is that correct? How about Panels? I've both pointed PSP to the Perfect Resize directory, as well as copied the plugins into PSP's default plugin directory. No joy in either case. Both programs are x86 & x64 and neither makes a difference.
Are there any logs that may indicate whether the plugin is being loaded, or errors if it's not?
Thanks,
Brad
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Perfect Resize Photoshop plugin in X6?
Post by LeviFiction »
Panels are not supported. 8li are file format plugins correct?
If that's the case then I would guess closest equivalent would be File-> Import menu. This assumes, however, that this particular plugin can be used with any software other than Photoshop. There are still somethings that are Photoshop only that other programs cannot properly duplicate.
